View Full Version : The LSX Forum
Pages :
1
2
3
4
5
6
7]
8
9
10
11
12
13
- Ls2 cam (6 replies)
- Power steering pump overflowing. (6 replies)
- how streetable is this cam? (12 replies)
- L76 g8 motor in 67 camaro (4 replies)
- No oil pressure. (4 replies)
- Power Steering hookup advice.... (6 replies)
- V8 LQ4 Engine (4 replies)
- Help.. 67 camaro w/ lsx454 swap.. Starts but dosnt stay running.. (8 replies)
- 1994 4l60e with a 5.3 swap? (3 replies)
- Gm ls3/7 power steering hose/fitting problem (19 replies)
- Will polishing the inside of the LSA supercharger hat make a noticeable difference? (6 replies)
- LQ9 vs LQ3 exhaust manifolds (0 replies)
- MY Planned LS swap, existing LSer's please read and advise (3 replies)
- 1968 Pontiac LeMans (0 replies)
- Radiator hoses - LSX 1st Gen. (2 replies)
- 68 Camaro LS3 with DSE front clip motor mount question (1 replies)
- LSA advice please? (16 replies)
- Turnkey Supply Engines (2 replies)
- Ls1 build question (17 replies)
- Best heads for LS1 (6 replies)
- How to adapt Lokar throttle cable to the firewall? (1 replies)
- Intake for LS engine (5 replies)
- LS motor pricing in future? (9 replies)
- LS Steam Vent Tube - Best place to tie into cooling? (32 replies)
- Aeromotive Regulator or Corvette FPR for 430" LS7 (0 replies)
- Wiring kit + computer for 5.3L swap (4 replies)
- New Vintage USA Gauges. (3 replies)
- Throttle Body Question (5 replies)
- Starter Woes on my new LS1 (16 replies)
- LS3 Crate Engine (40 replies)
- please help 1st gen camaro ls swap - power steering pulley? (3 replies)
- LS2 swap questions (7 replies)
- L92/LS3 issues. (4 replies)
- LS/Muncie combo tune (0 replies)
- PCV Question (16 replies)
- MAF location in intake tube?? (4 replies)
- 2008 LS2 cam sensor wiring pictures or diagrams please? (8 replies)
- LS start up precautions. (4 replies)
- Tried starting motor today.... fired but didn't stay running. (6 replies)
- HELP, LS2 not getting injector signal, starts on starting fluid though (6 replies)
- Time to buy a starter for my LSX454 (8 replies)
- noise in engine (13 replies)
- considering upgrade from 98 ls1 to 2004 ls1 (2 replies)
- What rear gear ratio with LSx driveline (8 replies)
- Lq9 with ls6 intake.... (10 replies)
- Performer RPM? (4 replies)
- Radiator hoses used in a 69 Camaro w/LQ4?? (2 replies)
- Painting aluminum block and heads (LS3). What to use??? (0 replies)
- Ls6 intake (4 replies)
- Doug's Headers in '65 Chevelle (2 replies)
- LS3- Whipple 2.9SC- Vintage Air geniv- 69 camaro (7 replies)
- Dry sump tank in trunk? (1 replies)
- fuel sump reversal (0 replies)
- ARH LS header question (0 replies)
- does anyone make first gen ls swap headers that don't hang below the sub? (13 replies)
- LY6/6L90E Questions.. (6 replies)
- ls1 swap help needed (5 replies)
- Dumb LS3 fuel rail question (1 replies)
- oil pan hitting crossmember (2 replies)
- 1997 corvette alternator,how do I wire it to work without PCM?? (0 replies)
- 2000 5.3 same mounts as ls2/3? (3 replies)
- Wegner -Retro- diamond cut accessory drive system. (9 replies)
- Is a PCV Oil Catch can necessary on LS engines? (43 replies)
- LSXrt in 1st gen F-body? (1 replies)
- charcoal vapor cannister help (5 replies)
- sbc to LQ4 swap turbo'ed (0 replies)
- Patriot LS6 CNC Heads (1 replies)
- waterneck hardware (1 replies)
- When is the new Gen V motor coming out? (1 replies)
- Copper in oil (3 replies)
- e40 ECM Startup tune (5 replies)
- ls newb needing some help (11 replies)
- Header evac holes for O2 sensor (0 replies)
- Electric Fuel Pump for my carb'd LS (8 replies)
- Can GM MLS head gaskets be reused? (7 replies)
- LS swap kit?? (4 replies)
- LS 2 with Dynatech headers which spark plugs (4 replies)
- LQ9 build..... (5 replies)
- Set Back/Adjustable LS motor plates/mounts (1 replies)
- Iron LS3 vs Aluminum? (5 replies)
- Texas Speed & Performance Shop Tour! (4 replies)
- Needing some help getting the LS2 started (13 replies)
- another69 camaro dse sub w ls6 question (1 replies)
- What does everyone think of the engine mounts tehy used for the sawp (4 replies)
- Reliable Source For LS Engine (CA) (11 replies)
- Looking for ideas on budget LS1 build (11 replies)
- 411 PCM pin out ? (3 replies)
- ran into problem with the Scroggin Dickey clutch bracket for LS swap (5 replies)
- How much oil? LS with Autokraft pan (7 replies)
- L92 turbo build or LQ4/9 Turbo build (7 replies)
- Oil Pan Clearance Help (17 replies)
- Spark Plug Wires (1 replies)
- LS1 Fuel line (stainless hard line to rubber hose help)!! (8 replies)
- Budget LS1 cross ram intake (21 replies)
- Shifter Needed (4 replies)
- dakota VHX gauges (5 replies)
- Cost$$$$$ (1 replies)
- Lifter Tray help (2 replies)
- Building LQ4 or LQ9 should I go EFI or Carb? (0 replies)
- Oil pressure sensor for gauges - Location?? (17 replies)
- LS oxygen sensors - upstream? Downstream??? (2 replies)
- Gen III ECM's (5 replies)
- LS steam tubes?? (3 replies)
- LS Fuel System for 1978-1981 Camaro (1 replies)
- 05-06 GTO LS2 E40 engine harness "White" connector pinout please (9 replies)
- What does "LS" stand for?? (16 replies)
- '05 lq4...do I ask for the harness and computer? (11 replies)
- Calling all 1st and 2nd Camaro LS swap owners! (57 replies)
- Trying to choose valve covers for LS3. Do I need threaded holes in them? (2 replies)
- New Edelbrock 2300 TVS Supercharged 416 ci LS3 Crate Engine (12 replies)
- WB feedback? (0 replies)
- ls1 long block? (7 replies)
- Quick S&P motor mount question (2 replies)
- Dry sump Tank into 2 gen camaro (2 replies)
- Motor mount fitment issue (4 replies)
- Firewall clearance? (1 replies)
- cruise control setup on 5.3L (12 replies)
- Planning LS swap into 66 GTO (4 replies)
- ls7 oil pan question (2 replies)
- Anyone running LS7 Crank and Dry Sump in LQ4/9 iron block? (9 replies)
- "just wondering" ls fuel pump (3 replies)
- LS1/1969 Camaro Install - clutch master cylinder and pedal questions (5 replies)
- LS1/LQ4 Turbo questions/ exhaust headers? (9 replies)
- HELP - Correct LS1 Head Gasket ID? (5 replies)
- Lowest cost option for LS Accessory drive? (11 replies)
- 5.3 Coolant loss (5 replies)
- 5.3 swap wont run above 160* going down the road (12 replies)
- RHS Block LS Pricing (2 replies)
- Good radiator info (5 replies)
- Aftermarket LS9 operatig system (0 replies)
- Destroked, Boosted LS7? (13 replies)
- Anyone work for GM, or GM race shop? (7 replies)
- Looking for engine builder recommendations (7 replies)
- How strong is the bottom end (4 replies)
- IPS Motorsports in Columbus Ohio reviews? (2 replies)
- Where to get LS2 E67 connector pins? (7 replies)
- 68 w/ S&P mounts and Dynatech (17 replies)
- LS Wiring Harness (32 replies)
- Mike Norris Motorsports EFI Tuning In SoCal - RTTC 2012 March 8-11 (1 replies)
- shop recommendations for ls swap into 68 camaro (15 replies)
- Mating 6.2 to 4l80 (6 replies)
- Drive by wire - intermittent operation?? (6 replies)
- FREE HEADERS - LSx into C10 (1 replies)
- ls3 416 stroker Head gasket help!! (3 replies)
- What wire connects to the starter solenoid? (4 replies)
- LS1 Power steering hose to 1st Gen F body info needed (2 replies)
- Which stock car LS2 throttle body? (17 replies)
- ls3 stroker need camshaft advice? (2 replies)
- Any issues using non-LS radiator for LS2 swap (6 replies)
- Accessory Drives - Anyone using the March Performance Pro Track setup (33 replies)
- LS3 Stock oil pan--good enough for Track Days & Auto Cross? (8 replies)
- PCM location (6 replies)
- what ecm are you using when doing a ls swap (18 replies)
- Texas Speed has Moved! NEW PHONE NUMBER!!! (1 replies)
- Engine Builder In Ga (4 replies)
- Ls1 to corvette transaxle (2 replies)
- Engine Builder (9 replies)
- Ls Choices (0 replies)
- ls7 stock injector flywheel hp (12 replies)
- 5.3 engines (2 replies)
- Need decent plug wires! (5 replies)
- Need g-body LSX Frame no (0 replies)
- coolant temp sensor (3 replies)
- LS 2 install in a 69 Firebird (4 replies)
- Z06 Cam in 5.3L (9 replies)
- Oil coolers?? Need one? (1 replies)
- ls headers for art morrison subframe (5 replies)
- How are you connecting to the quick connect fuel fitting on the intake? (5 replies)
- loud knocking noise (14 replies)
- Intake Tube Help Request (7 replies)
- Plug for LS1 cam sensor hole in block? (7 replies)
- Taking the jump ( I think) (3 replies)
- Used LS engines (7 replies)
- LS1 vs LS2 intake - fuel rail (8 replies)
- I want to build a cold air intake (5 replies)
- LSX "Classic" intake (9 replies)
- LS engine with best horsepower to gas mileage ratio? (3 replies)
- Free Crate and Cradle W/ Any Engine Purchase @ Texas Speed! (0 replies)
- Lq4 supercharged???? (3 replies)
- Question: LM7? (6 replies)
- 68 camaro - ls motor, 4l80e trans- what mounts fit? (2 replies)
- spun bolts in aluminum (1 replies)
- What mounts have you match with Dynatech headers (715-21410) on your 1st gen F body? (33 replies)
- About to take LS1 plung..need advice (25 replies)
- 6.0 LS Newbie question (5 replies)
- Budget LS engine questions, 5.3 or 6.0? (5 replies)
- LS6 T56 into 66 Chevelle... Help (9 replies)
- 5.3L G-body Cutlass (2 replies)
- Question 6.0 LQ4 (12 replies)
- Mass Airflow Part Number (2 replies)
- Trade LS2 controller for GM LS376/480 controller ECM PN 19258268 (0 replies)
- Can the driverside header be put in aftre the engine? (3 replies)
- 6.0 LS Question (8 replies)
- Oil bypass cover (0 replies)
- Crazy wild cylinder head idea (5 replies)
- Needing help with lsx power steering hoses to factory box (6 replies)
- Help with identification on new vehicle (26 replies)
- Clearance issues: How much is enough, Stainless Works headers & ATS 670 Gearbox (0 replies)
- Which LS??? (5 replies)
- new site sponsor "JJs automotive" (3 replies)
- What windage tray? (4 replies)
- Pulley Direction and RPM (7 replies)
- stock ls2 idle number? (1 replies)
- LS1 PCM Mounting Pics Needed (9 replies)
- Low mount A/C for 1st gen Camaro with LS Engine (16 replies)
- Vent systems that you KNOW work (10 replies)
- LS3 MAS Problems (2 replies)
- Ls3 /brake booster size (0 replies)
- LS3 Motor w/ Billet Speciality Tru Trac System Problem (1 replies)
- ? On LS computer mounting under the fender on the firewall? (7 replies)
- Does anybody make a swapkit to put a LSx/6L80e(or 6L90e) combo into 77-96 GM B-Body?? (4 replies)
- How much was your cold air intake? (6 replies)
- What are the simplest ( LS ) motor mounts for 1969 camaro? and where should i buy the (61 replies)
- L92 with LS3 intake vacuum quesion (9 replies)
- LS1/T56 1st gen Camaro Question (10 replies)
- My very first LS1 (7 replies)
- Anyone Swapped a LSX into a 73-77 GM A Body Car Such As A Cutlass, Regal or Malibu??? (4 replies)
- lsx header info---please post your setup (1 replies)
- LS1 PCM Choices - Help please (13 replies)
- LS1 Technical assembly info? (2 replies)
- Will this work? (4 replies)
- LS dyno (8 replies)
- Who has installed a LS engine in a '68-'72 GM A body? (15 replies)
- 5.3L cam recommndation (8 replies)
- Looking at this cam for my LQ9. Opinions? (5 replies)
- LS front accessory serpentine setup question (3 replies)
- Vented Fuel Cap (2 replies)
- harness hole first gen (2 replies)
- 1st gen f body, lsx swap, BRP mount and hooker swap headers a no go (3 replies)
- 1st gen F body Hood clearance issue, carb'd L92 (6 replies)
- Need transmission cross member for LS2/4l70e in my 69 Camaro (1 replies)
- Coils.....where'd ya put them. (4 replies)
- 5.3 LM7 rebuild - is it worth it? (5 replies)
- Ls1 oil sending units? (16 replies)
- 69 Camaro ls1 radiator hoses? (6 replies)
- LS3 Fuse Box Terminations (0 replies)
- best spark plugs? (11 replies)
- Oil Pan needed for LS3 (4 replies)
- Floor-Mounted DBW A-Pedal? (6 replies)
- Need help with LS3 Connections (4 replies)
- Aftermarket coil brackets? (1 replies)
- headers before or after install (8 replies)
- Something stupid I did (LS2) (9 replies)
- LSX Blower Setup (26 replies)
- LS6 into a 74 c10 (7 replies)
- '06 5.3 (6 replies)
- 1970 Mustang LS3 (1 replies)
- L92 flywheel recomendation? (9 replies)
- Prodigy Power LS 6.2L, 11.80 / 116MPH CR in 3650LB Pro Touring Car! (24 replies)
- 3 valve 4.6 into a 67 fastback (10 replies)
