View Full Version : LS2 swap questions
Houston_t
04-14-2012, 05:53 AM
So I finally picked up my motor it's a ls2 out of a trail blazer ss, I plan on converting it over to a carb setup and had a few questions. First can I buy the kwik alt and power steering relocation bracket and run my truck accessories ? Also will the truck water pump work with the carb intake ? I see most people change them when they do their swap but that's mostly because they go with the car intake and throttle body. Last how do I tell if my motor is vvt and what tooth reluctor wheel it has ? Thanks in advance
rallystyle
04-14-2012, 11:30 AM
what car is it going in?
Houston_t
04-14-2012, 11:46 AM
sorry about that i copied and pasted from another site im on, its a 78 trans am
Hugger67RSSS
04-14-2012, 02:11 PM
Kwik brackets and truck accessories will be fine. The crank sensor will be black if it is a 24x motor, if it is above an 06 it will be 58x and have a grey plug. As far as I know none of the ls2 motors have vvt. I have the same motor with a carb setup.
Houston_t
04-14-2012, 04:03 PM
Where is the crank sensor located, is that the one on the timing cover ?
BuzzKillian
04-14-2012, 04:58 PM
It is by the starter.
Houston_t
04-14-2012, 05:12 PM
ok its grey so i guess i have a 58 tooth, now i dont have to worry about buying the wrong msd box. thanks for the help guys
Hugger67RSSS
04-14-2012, 06:20 PM
Yep get the msd 6012 and your good to go
