View Full Version : dakota VHX gauges
fast
02-14-2012, 07:10 AM
anyone using these in an LSx swap?
if so using the odb2 add-on?
trying to decide if need the odb2 add-on or not?
('68, stroked LS2 using LS1 harness)
thanks!
neki67
02-14-2012, 11:28 AM
I'm installing them in my Camaro right now. I'm not intending to use the OBD2 add-on and as far as I read the instructions, no need for it.
neki67
02-16-2012, 02:13 PM
Finished the installation of the VHX gauges today and can confirm you don't need an OBDII add-on. Optionally you could use one instead of the sensors that come with the gauges. In case you want to avoid extra wiring in the engine compartment you can use the signals from the OBDII.
For the record; everything (sensors, adapters, wiring) is included in the kit. The manual/instructions is/are also very clear and setting up the gauges is quite easy and very versatile. Highly recommended mod and well worth the money.
fast
02-16-2012, 06:06 PM
awesome and thank you!
howehot
02-18-2012, 07:41 PM
Is this unit compatable with the FAST XIM and TCI TCU units.
neki67
02-19-2012, 02:58 AM
The Fast XIM module will undoubtly give you a tach signal, the VHX gauges can be set up for several different signals (5V square and 12V). Even the reaction time of the dial can be set (Fast, Medium, SLow).
The TCI TCU will provide the Speed signal (VSS).
Rest of it is stand alone and not depending upon the ECU and/or TCU.
