View Full Version : Motor mount fitment issue
LSxChevelle
01-27-2012, 05:46 PM
So I took a spare block to see where it would sit with my mounts...
I have the $30 3/8" eBay plates and standard 350 mounts.
Issue is that when I bolted passenger side in the other can't set into place. The bolt hole in motor mount is up and out like 3/4".
Sorry for the crappy paint pic...
54746
andrewb70
01-27-2012, 06:11 PM
Some of that can easily be caused by frame sag. What engine mounts are you using?
absintheisfun
01-27-2012, 06:15 PM
If you can, get a better pic...
I had the same problem and it was two things:
There are short wide and tall narrow SBC mounts...make sure you have the correct ones for your application...
And
The frame was tweaked causing the mounts not to line up correctly
LSxChevelle
01-27-2012, 11:54 PM
I'll pay around tomorrow after I get my L76. I'm using the short and wide. The mounts are nee and I just bolted then to the 350 I'm also selling tomorrow and it set right in no problem. I'll get a better pic Sunday if I'm still having issues.
dhutton
01-28-2012, 06:21 AM
I read somewhere that the plates are supposed to be 5/16 not 3/8 thick. This might account for some of the problem.
