View Full Version : 69 Camaro ls1 radiator hoses?
69blackwhss
08-15-2011, 11:20 PM
I have a 69 Camaro with the stock radiator. Am going ls1 but what radiator hoses do I use I can't find any info? I want to keep my stock radi. If I can. I need upper an lower hoses Thanks guys
69blackwhss
08-18-2011, 01:36 AM
Anyone
dhutton
08-18-2011, 04:03 AM
Try over on ls1tech.com in the conversions and hybrids forum.
69blackwhss
08-18-2011, 11:49 AM
Ok I'll
Try ls1tech too
BulldawgMusclecars
08-18-2011, 01:41 PM
Something else you might try is making a template out of wire or something similar (I use scrap aluminum 3/8 tubing since its easy to bend and holds its shape), and going to the parts store. That is what I typically do, and it works well. Just make sure you measure each end beforehand with a caliper, and take the caliper with you. Rarely takes more than 5-10 minutes of looking around to find the perfect hoses.
Z06vet
08-19-2011, 04:45 PM
The stock 69 rad has larger outlets than the LS1. You may be able to stretch the LS1 size hoses over the 69 outlets. I have also run across some hoses that were sized differently on each end. If the parts store will let you in the back to search thru all the hoses u will probably find one that works.
69blackwhss
08-19-2011, 05:50 PM
Thanks guys for all the help!!
