View Full Version : LSX Blower Setup
AZSaleen04
07-28-2011, 02:42 PM
Has anyone gone with a blower setup such as a Kenny Bell Roots style or anything else for an LSX?
I started entertaining the possibility of a blower.
Ron.in.SoCal
07-28-2011, 07:29 PM
They're all over LS1Tech. Many say the LSX block is a better candidate for boosted applications...
67 ls1 vert
07-28-2011, 09:02 PM
I have a LS2 with an f2 im building.
Had a KB before I went with the F2.
ProdigyCustoms
07-29-2011, 04:18 AM
This is the hottest thing going in Blowers for LS. This is a special MaganCharger combined with a special modified version of our popular Wegner front drive. The very best for many reasons all related to belt type, belt routing, belt wrap. The blower is driven by it's own 10 Rib belt with over 180 degrees of belt wrap which prevents hated belt slippage commonly associated with blowers. Especially important in blower cars that are autocrossed and road raced with quick on and off the gas situations.
When you combine the OEM quality of MagnaCharger the the very best front drive, it is the clear winner.
jy211
07-29-2011, 04:52 AM
Boing...:)
blakgoat
07-29-2011, 05:27 AM
these pics look familiar Frank, well this is the direction I am going, I wanted something I could drive around town and have something I could beet on at the track, Frank has my setup at the dyno shop getting tuned,............lets see some numbers!:cheers:
AZSaleen04
07-29-2011, 07:56 AM
Thanks for the info as I'll need to do a bit more research.
Frank I have a L92 motor, Texas Speed Cam, LS3 Intake which won't be needed, Corvette accessories and the Vintage Air/Quick coonect I purchased from you. Will I need accessories be needed as well if I go down this route?
Based on the accessories and the L92 heads are there other bloweres that would also work?
Thanks!
AZSaleen04
07-29-2011, 07:57 AM
What made you change directions away from a KB? I had the KB 2.8H on my Saleen Cobra that was a moster of a blower.
67 ls1 vert
07-29-2011, 08:13 AM
I changed direction because of the computer tunning. I am using a carbed set up now with a blow through. Very simple set up using the MSD 6010 box that controls the ignition, cam, crank, tunning.
AZSaleen04
07-29-2011, 08:26 AM
Got it nice setup.
CFster
07-29-2011, 11:26 AM
Ok Frank.
How much?
CFster
07-29-2011, 11:37 AM
And what kind of coil brackets are those?
Jim98ta
07-29-2011, 06:33 PM
I'm doing a mild setup with a Vortech T-trim. LS2 bottom end (stock) with LS3 heads and a custom cam. Blower bracket is for a Corvette, with Corvette accessory drive. Still got a way to go....
48467
AZSaleen04
07-30-2011, 05:44 PM
48467
I have the L92 heads on mine. Are the ports the same on a L92 and LS3? If so then I guess a Corvette setup would work.
daytonayellaz
08-01-2011, 08:13 PM
Ok.... Mike.... What are you up to now?? LOL.. To answer this question, Yes... the L92 heads have the same ports as the LS3
daytonayellaz
08-01-2011, 08:15 PM
48467
Wow! That looks really nice Jim. Do you have a build thread going?
ProdigyCustoms
08-02-2011, 03:38 AM
Ok Frank.
How much?
Complete Blower and Drive System is $8800. Keep in mind the kit includes the front drive which includes A/C Compressor, Alternator, PS Pump, ATI Balancer.
We can also set up the MagnaCharger blower with LS3 Accessories but the net savings is not to much unless you already own the LS3 accessories
ProdigyCustoms
We have those also from Wegner
ProdigyCustoms
08-02-2011, 03:40 AM
Yeah, exactly. L92 and LS3 heads are exactly the same except the valves are hollow on the LS3 and solid on the L92..
CFster
08-02-2011, 08:07 AM
I already have a C5 accessory kit. My compressor is on a Kwik bracket. Would that work?
Jim98ta
08-02-2011, 08:45 AM
daytonayellaz,
No build thread for it. I should start one, but progress is kinda slow at the moment.
ProdigyCustoms
08-02-2011, 04:24 PM
I can whip up something for you
LS1-IROC
08-04-2011, 08:18 AM
Here's my MP112 on a stock little LS1..runs well. I like the Magnacharger because of their track record for reliability. KB makes a nice unit too...just out of my budget for this build....lol. I chose a positive displacement blower for the low end torque. They make serious torque down low...IE...my stock LS1 has 425ft/lbs at 2500rpm. You do sacrifice a little on the top end though, but my car is a street car, not a race car so I was willing to compromise.
MattG
08-12-2011, 02:43 PM
Man that is down right sexy!!!!!
MattG
08-12-2011, 02:45 PM
I hit the wrong button! The other maggie is still sexy, but this 2300 set up is my dream blower setup!
absintheisfun
08-13-2011, 03:20 PM
How hard is it to throw a magnacharger on an LS with the vintage air front runner...is there a need for an all new accessory drive system?
ProdigyCustoms
08-14-2011, 05:59 AM
Best I know no one has combined the VA Front Runner and blower. Belt line spacing is slightly different, there are idlers and tensions to work into the system. I suspect it could be done but the R and D would be extensive.
The one thing (of many things) that is so wonderrful about the Wegner / Magna is the independant 10 rib drive for the blower. That would be very difficult with the bracket design of the VA Front Runner.
