View Full Version : Ls1 oil sending units?
69blackwhss
08-15-2011, 11:25 PM
Am putting an ls1 in my 69 Camaro. I saw were people have drilled the oil sending unit down by the oil filter. But I was worrying if I can use the stock place up by the intake were the old school oil pressure sending unit was. I now there's a elec plug in the hole rite now could I use that to a elec oil pressure gauge? R that the elec plug out an use a mechi. Oil pressure sending unit an mechi gauge like I have used for the old big block? Any info would be great guys I would like to have it together befor ls fest in ky
garys 68
08-16-2011, 04:17 AM
Here ya go. An adapter for 1/8" NPT in the original sender location.
I'm using it with a mechanical gauge on one motor and electric sender on another.
http://www.speedwaymotors.com/LS-Series-Oil-Pressure-Sender-Adapter,20928.html
69blackwhss
08-16-2011, 11:51 AM
Thats great man thanks!
Z06vet
08-17-2011, 11:55 AM
Just remember the computer needs to see oil pressure, so as long as you retain the oil pressure sender for the computer, should be fine. I drilled & tapped the blank plate above the oil filter. It was easy, and more accessible. Either way id fine though. Enjoy the LS motor.
Taylor1969
08-17-2011, 12:14 PM
You sure the computer needs this? I don't have it setup for mine and it seems to run. I am using the factory hole with the adaptor as shown in the post above.
Chris
12sec ss
08-17-2011, 02:16 PM
Computer only NEEDS to see oil pressure if the motor has Displacement On Demand technology. Otherwise, no.
Z06vet
08-17-2011, 02:27 PM
Sorry, i was told i needed to retain the oil pressure sending unit that goes to the engine harness. I have not had a problem where that was an issue, just what i was told when i did my install. My apologies if that was incorrect.
Ishmael
08-17-2011, 02:42 PM
Is there a way to use that original sending unit?
evostilo
08-17-2011, 04:14 PM
Are you running an LS1 or a newer LSx eng. And i wonder if maybe the newer ones need to retain the Original or Vise Versa?
12sec ss
08-17-2011, 07:24 PM
instrument clusters in newer cars get all their information from the engine computer, so if you left the oil pressure sensor there it really does nothing as most people woun't use a factory cluster from a new car in their swap. Late model motors that have DOD and shut off cylinders, need that oil pressure input for their internal calculations. That's pretty much it. Personally Im using New Vintage gauges, and used that port for the sending unit.
69blackwhss
08-18-2011, 01:32 AM
So I can use the stock sending unit hole for a mech oil gauge rite? U guys keep goin back in foth on me. Lol... Am keeping the ls1 stock sending unit the elec one for further use when I redo my car I'll be goin with a new dash an be tuning all elec gauges besides the speed-o. So u guys think this will work for want I want to do?
Thanks jason
garys 68
08-18-2011, 04:25 AM
Use the adapter, hook up your mechanical gauge.
Throw away the LS1 sender, it will only work with the original dash gauge and that runs through the ecu. Your new gauge will come with a 1/8" NPT sender.
69blackwhss
08-18-2011, 11:46 AM
Thanks garys 68
Taylor1969
08-19-2011, 07:35 AM
Here is my autometer electrical sending unit (go this way for sure as you won't ever have the leaking tube issues). The sending unit doesn't have any trouble clearing the intake.
https://static1.pt-content.com/images/pt/2011/08/IMG_0181-1.jpg
69blackwhss
08-19-2011, 12:55 PM
Looks good but little hit ain't it won't it show over the intake? I
Was hoping to
Use the one from my big block were it's hooked up
I
Just need the fitting
BulldawgMusclecars
08-19-2011, 01:42 PM
I had been told an LS3 needed to see it, but found that was incorrect when I did the 376/480 swap a few months ago. There wasn't even a connector for it on the GMPP harness. If you don't want to drill anything, and are worried about appearance, or clearance issues with the firewall or intake, use the above adapter (or one from Autometer) and run an AN 1/8npt to -3 adapter, and you could use hardline or a teflon line to relocate the big ugly sending unit wherever you want it. Easy, and its not that expensive to do.
69blackwhss
08-20-2011, 01:32 PM
thanks guys!!!
