View Full Version : Plug for LS1 cam sensor hole in block?
GeoffP
11-08-2011, 03:27 PM
Does anyone know of a good way (not something rigged - want to fix it right) to plug the cam sensor hole in the rear of an LS1 block? I won't need to use it since I'm running an E40 ECM and am converting my engine to a timing cover cam position sensor.
John@Texas-Speed
11-09-2011, 01:30 PM
We usually just leave the old sensor back there but unplugged so the hole is covered. If you want something like a plug that is fit for that hole I have no idea, I figure you would have to make something.
GeoffP
11-09-2011, 01:49 PM
Ok I was trying to get out of buying a sensor just to plug the hole.
12sec ss
I'd also leave the sensor there unplugged. Its not like its visible
GeoffP
11-09-2011, 02:49 PM
Can anyone tell me if the sensor provides any oil galley sealing points (like a Gen I distributor does) where if I plug the hole with an expandable freeze plug that it won't cause problems? I was hoping someone knew exactly what size brass or steel freeze plug to use to plug it.
John@Texas-Speed
11-10-2011, 09:19 AM
The cam sensors do have an o-ring on them that provides a seal. I don't think you would be able to get an expandable plug to work because that o-ring seals way down at the bottom very close to the cam. I am not sure that a plug would be able to seal all the way in there.
GeoffP
11-10-2011, 09:43 AM
Thanks - I looked at one online last night and noticed the o-ring. I bought a used one on eBay for $15 shipped so that'll take care of the sealing issue. Thanks for everyone's input!
parsonsj
11-10-2011, 10:27 AM
The boys at Wegner might have 'em:
http://s41657.storefront-solutions.com/SearchResult.aspx?CategoryID=30
