View Full Version : LS 2 with Dynatech headers which spark plugs
Fast 82
03-01-2012, 08:12 AM
Question; I have installed dynatech headers on my 69 Firebird LS2 and the stock wires hit the headers. Which spark plug wires should I use?
boostin05blacksti
03-01-2012, 11:07 AM
I have the same headers and still need to adress this issue but from the reading Ive done the MSD kit is part number 3301 and will work. See the thread here..
http://ls1tech.com/forums/conversions-hybrids/1374562-68-camaro-ls3-t-56-header-question.html
Z06vet
I am putting some 90* boots on those 2 plug wires. They are going to clear the header tubes, but when pushed all the way on the spark plug, the boot is right against the header flange. Not sure if this will work long term, but may need do do something different later on. Scott
69cutlassrkt
03-01-2012, 11:04 PM
I'm using multi angle msd spark plug wires on mine cause I ran into the same problem.
Fast 82
03-02-2012, 06:25 AM
MSD recommended part number MSD32819, so I purchased them. I will let you guys know how they fit once I get them. Thanks for the responses!
