View Full Version : The LSX Forum
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13
  1. What would you do? (2 replies)
  2. starter hangs up (5 replies)
  3. noise in engine (8 replies)
  4. Road trip! Picking up my LS2/4L70E tomorrow! (10 replies)
  5. Need help fast LS2 in a Chevelle (8 replies)
  6. SSTB LS2 into 67 Camaro (25 replies)
  7. Sheetmetal intake measured performance (1 replies)
  8. Hood clearance (0 replies)
  9. LS engine harness locaiton through firewall? (6 replies)
  10. Question about idle speed and gear selection with LS2 4L70 (7 replies)
  11. Removing original ls1 Intake fuel line fitting...need some help! (1 replies)
  12. What LSx headers to use for a '91-'96 B-Body (Impala SS)? (0 replies)
  13. Is this LS2 timing chain too loose? (2 replies)
  14. T56 Clutch Master Q - Again lol (4 replies)
  15. Which gauges (22 replies)
  16. LS7 / Z06 Oiling Issues (8 replies)
  17. New Texas Speed & Performance Engine Machining Center! (5 replies)
  18. I'm taking the LS plunge! (24 replies)
  19. L92 in 68 camaro fuel pump? (3 replies)
  20. Fuel tank vent problems (5 replies)
  21. Hope you can all help me ls oil pan ? (0 replies)
  22. LSA outboard engines (2 replies)
  23. LSx conversion owners. In hindsight what would you have done differently (23 replies)
  24. does anyone know main bolts length and thread? (1 replies)
  25. 5.3 shorty headers worth it? (6 replies)
  26. engine swap (3 replies)
  27. LS3 pistons, flat, dished, valve reliefs? (2 replies)
  28. Oil Pan Gasket (3 replies)
  29. JCG/Vaporworx Gas Tank (8 replies)
  30. i need 68 camaro 6 cyl Accelerator Pedal Assembly please help (3 replies)
  31. 2001 trans am, need some help (1 replies)
  32. Are LS7's worth the bucks ? (11 replies)
  33. 68-72 A-body LSX swap guys in here (4 replies)
  34. LS3 Wiring Diagram (6 replies)
  35. LS engine conversion for my camaro (14 replies)
  36. How much ground clearance to the aluminum pan on your LS swap? (3 replies)
  37. Anyone done an E-Rod? Need some info on the charcoal cannister. (0 replies)
  38. fuel rails for L76 intake? (0 replies)
  39. Acc drive in a 67 Camaro (4 replies)
  40. 2nd Gen LSX Trans Am with Functional Shaker (1 replies)
  41. LY6 with LS2 throttle body and E38 ECM with VVT ?? (1 replies)
  42. Is an LSx engine swap worth the wiring hassle? (16 replies)
  43. A-body LSX Swap guys in here (7 replies)
  44. LSx Engine Build & Install Help Needed (2 replies)
  45. holley ls3 and l92 intake (2 replies)
  46. preparing my wagon for EFI LS swap, What to do??? (0 replies)
  47. Headder to ps hose clearance. Is this too lttle? (2 replies)
  48. Oil Cooler/Tranny cooler for a L92/6l90e swap into a 67 Camaro (3 replies)
  49. LS that revs to 7500 RPM (24 replies)
  50. L92 not fitting in frame any help? (11 replies)
  51. 5.3l Swap Advice (5 replies)
  52. Oil pickup tube girdle: gauging intereste before I have them made (20 replies)
  53. Making your factory gauges work with the LS engines! (3 replies)
  54. Cruise control on a reworked LS2 harness (28 replies)
  55. LY6 to go 24x & Cable or keep 58x reluctor and DBW? (5 replies)
  56. AC Bracket for a L92 in a 67 Camaro (5 replies)
  57. LQ4 Possability's?? (22 replies)
  58. Is there a need to switch from a single bolt cam to a 3 bolt one? (2 replies)
  59. Someone pls help! (1 replies)
  60. Connceting fuel lines to the LS quick connecting fuel rail connection, how? (5 replies)
  61. Help me choose a cam for a LS3 cause I have no clue!! (19 replies)
  62. Do I need mass air sensor? (3 replies)
  63. MAT Sensor (3 replies)
  64. Speartech vs GM ECU (0 replies)
  65. Stock GM balancer or aftermarket? (5 replies)
  66. Billet valve covers for LS3/L92. What do I need on them? (0 replies)
  67. LQ9 w/LS3 Heads - What controller & harness to use? (2 replies)
  68. Alternator Bracket for LS1 (0 replies)
  69. I need to get some stock LS3 injectors! (1 replies)
  70. Fuel rails for 6.0 with L76 intake (0 replies)
  71. L92/6L90e performance mods in 67 Camaro (2 replies)
  72. Recommendations for intake / throttle body porting? (0 replies)
  73. Newbie LSx questions (5 replies)
  74. LS3 vs L92 heads (valves) (3 replies)
  75. another ls pan question (28 replies)
  76. Which injectors do I need for my L92? (3 replies)
  77. MIL Wire Question (3 replies)
  78. 4.8 Swap? (21 replies)
  79. LSx front pulley system?? (11 replies)
  80. Would you call this a mild, decent size, or large cam..... (13 replies)
  81. Corvette fuel filter question. (5 replies)
  82. 58x reluctor - there's got to be an easier way. (0 replies)
  83. LQ9 into 69 camaro (7 replies)
  84. My LS3 crate has water pump hose on wrong side..Change? (0 replies)
  85. Aftermarket Harness - Oil Level Sensor - Oil Pan (1 replies)
  86. ordering my ls 1st gen f-body swap parts this week,suggestions please ? (7 replies)
  87. T56 shifter location. Do I need to move forward? (1 replies)
  88. LS7 injectors & throttle body (2 replies)
  89. C5 Vette Alt & PS on Trailblazer SS LS2? (5 replies)
  90. Aftermarket fuel rails (3 replies)
  91. Cam position sensor question (1 replies)
  92. LS Valve Covers (23 replies)
  93. any ls guys running sumped tanks, please post set ups (7 replies)
  94. Current Performance wiring harness? (8 replies)
  95. LS3 Engine covers? (2 replies)
  96. TransDapt LS Series Mounts and pictures (1 replies)
  97. ls mount (0 replies)
  98. LS3 Flywheel Dowel? (2 replies)
  99. Help with LQ4/LQ9 pricing questions and best setups to buy (4 replies)
  100. DBW Pedal Mounting option (2 replies)
  101. Street and Performance Motor Plates...What motor mounts??? (0 replies)
  102. Your best MPG with your LS motor (8 replies)
  103. Stuck on engine direction (4 replies)
  104. Why the hell are LS valve covers so expensive??????? (5 replies)
  105. Do LS3's need an oil cooler? (15 replies)
  106. Harmonic Balancer??? (1 replies)
  107. Water pump question (3 replies)
  108. any 1st gen guys running autokraft pan (7 replies)
  109. Oil Pan Baffles (3 replies)
  110. LS1 accessory offsets (5 replies)
  111. Ls2/ 4l70e (3 replies)
  112. engine mount help (4 replies)
  113. L92 PCM help...... which harness/controller? (21 replies)
  114. lsx cooling (2 replies)
  115. LS1 Build Help. Trying to get 500HP (6 replies)
  116. Road race oil pan from stock LS pan. DIY (1 replies)
  117. Want to confirm how to tune a self-tuning efi system lol (9 replies)
  118. any one using spectra GM32 fuel tank in 1st gen camaro (2 replies)
  119. Please explain this LS motor mount drawing (1 replies)
  120. T56 swap master cylinder questions (4 replies)
  121. wil corvette front drive asc work on a first gen ls swap (3 replies)
  122. LS2 GTO accessories - Radiator Q's (0 replies)
  123. LSx motor mounts, back of motor location VS normal small block chevy? (5 replies)
  124. Water pump spacers for L92 with VVT (9 replies)
  125. harness conversions (5 replies)
  126. lokar pedal (10 replies)
  127. 2011 Mustang GT Motor..... (0 replies)
  128. Another 'Should I buy an LS7' thread (3 replies)
  129. engine swap choice and questions (1 replies)
  130. Intake manifold question LS1 (4 replies)
  131. Tech II Scanner (5 replies)
  132. Taking the LS3 Plunge (19 replies)
  133. GM ECM and harness, Speartech or street and performance (3 replies)
  134. LS Air Intake Idea? (8 replies)
  135. ls pans milodon vs champ (15 replies)
  136. mast or retrolsx oil pans (4 replies)
  137. L92 vs LS3, L92 controller? (17 replies)
  138. what headers, mounts, crossmember did you use? (9 replies)
  139. Single bolt cam...Bolt part number??? (1 replies)
  140. need swap help ls1 in 68 camaro ? (16 replies)
  141. edelbrock intake? (2 replies)
  142. Anybody actually using the spectra tank (85 replies)
  143. Questions about CA and NV engine swaps and smog inspections (11 replies)
  144. Which reluctor wheel do I have? (1 replies)
  145. Vortech supercharging my LS1 swap. Help!! (4 replies)
  146. MAST motorsports controller or GM? (3 replies)
  147. Help! LY6/6L90 Swap (15 replies)
  148. What headers will fit a 1966 GTO with a 04 ls trans plant? (4 replies)
  149. just something cool (0 replies)
  150. inectors and fuel pump (6 replies)
  151. weird chirping noise - after installing ps pump?? (9 replies)
  152. l92 turbo intake!!!! (0 replies)
  153. LS2 running rough (3 replies)
  154. oil pressure sending unit leak? (5 replies)
  155. Will C6 manifolds fit LSX block and heads? (4 replies)
  156. Will my original clutch linkage work with my new LSX376 (6 replies)
  157. ls2 cam, intake manifold and carb (3 replies)
  158. Problems with Kooks custom conversion headers! (15 replies)
  159. Realized I have a 24x LS2 - Question About ECM? E67 or E40? (6 replies)
  160. swingin' (1 replies)
  161. Valve Spring question (2 replies)
  162. ls2 into 65 stang... (10 replies)
  163. LS2 Victor JR vs Performer RPM (4 replies)
  164. Anyone with a LS with C5 accessories/pulley's and stock control arms? (2 replies)
  165. clarification of accessory options with the LY6 (5 replies)
  166. Anybody run the EZ EFI on a LS motor for old school looK? (6 replies)
  167. ls1 or lq9 which one??? (16 replies)
  168. Ls7 with TH400 trans (3 replies)
  169. L92 accessory layout diagram? (2 replies)
  170. oil pan questions (1 replies)
  171. Air intake tube (10 replies)
  172. -6an too small for a breather tank? (0 replies)
  173. PS pully interference with stock Gen 1 Camaro subframe. (7 replies)
  174. best way to pull a flywheel from LS (5 replies)
  175. Modded LS2 as Daily Driver, Help Needed (4 replies)
  176. Cam change for LS6 researched, help. (5 replies)
  177. LSx & cruise control questions (1 replies)
  178. Need help ordering an engine ECM and Harness. (9 replies)
  179. what year did the ls2 reluctor count change (12 replies)
  180. Little off-topic - looking to do ECU update on mostly stock 5.3 Tahoe (1 replies)
  181. LS engine cover (12 replies)
  182. Can a non LS motor be made to run like a LS motor? (15 replies)
  183. LS1 starts but dies (8 replies)
  184. Have a line on a 5.3 (3 replies)
  185. LS9 Performance Upgrades & Modidications (3 replies)
  186. cts-v pan (1 replies)
  187. Is this a good deal on a LS6? (4 replies)
  188. charcoal canister? (6 replies)
  189. plug for stock oil sender? (0 replies)
  190. Weight of a LS3/T56 (0 replies)
  191. Ls2 72 chevelle (17 replies)
  192. Split Lock header bolts (2 replies)
  193. Most "budget friendly" LS Swap parts (37 replies)
  194. MEFI4 controller better than stock LS? (0 replies)
  195. speed denisty??? (0 replies)
  196. 6.0 ls2 bellhousing to fit a ford c4 tranny (1 replies)
  197. LS stroker crank? (3 replies)
  198. For those running a GM Controller for LS setup (50 replies)
  199. engine harness question (2 replies)
  200. Where to get great deal on LSX motors? (6 replies)
  201. upgrade to 243 or keep 241? (4 replies)
  202. Best 6 speed for crate engine? (1 replies)
  203. Did the Katech rod bolt upgrade today (1 replies)
  204. Question about Ls2 engines (0 replies)
  205. LS back from machine shop (0 replies)
  206. MSD/APS Starter -- GM LSX454 (1 replies)
  207. Stock L92 engine in a car? (26 replies)
  208. Radiator hose for 2nd gen (2 replies)
  209. LS header flange in 304 SS .500" thick (8 replies)
  210. Help me outfit my new LSX 454 for my 70 Camaro (3 replies)
  211. L76 into 69 Firebird - Steering Joint(s) Replacment (4 replies)
  212. Which ECM for an LS7? (9 replies)
  213. motor mounts for a '72 firebird? (1 replies)
  214. Tuner simulation softare? (0 replies)
  215. is there a problem with 98/7 ls1s? (6 replies)
  216. Most LS for the money? (17 replies)
  217. Mast Motorsports Controller/Tune question: (7 replies)
  218. fuel line limits (6 replies)
  219. LSX Tuners, need help determining detonation with HP Tuners scan files. (16 replies)
  220. DropOuts LS2 vs Ls3 (4 replies)
  221. Dry sump engine height drop (6 replies)
  222. GMPP muscle car oil pan (4 replies)
  223. LS3 rod bearings - please help (3 replies)
  224. will z06 cam drop right into an 08 5.3 lmg? (10 replies)
  225. Metric to standard fitting for mechanical temperture gauge? (6 replies)
  226. It's time for a little more mojo. (2 replies)
  227. Help! Abear hidden coil valve covers (7 replies)
  228. motor mount 68 camaro with muncie ? (0 replies)
  229. LS motor mounts for a '67 Firebird (6 replies)
  230. difference between 07 and 08 ls2 harness/ecm (2 replies)
  231. harness integration question (5 replies)
  232. 6.0 noisy valvetrain on startup.. what would you do? (29 replies)
  233. Mast Motorsports builds Ultimate NA LS Pump Gas Street Motor (870hp/665tq) (16 replies)
  234. LS6 Cracked Block Repair? (5 replies)
  235. Low Budget!? Use everything from LS 6sp swap car and finish around $4000? (8 replies)
  236. LS1 intake swap worth it ? (6 replies)
  237. RetroLSX (1 replies)
  238. dbw motor, dbc ecm? (7 replies)
  239. throttle cable for ls1 2nd gen? (9 replies)
  240. How much of this would swap out... (2 replies)
  241. need some LS 5.3L engine opinions (7 replies)
  242. injector size (3 replies)
  243. LSX454 Weight? (3 replies)
  244. Swap! LS1 or LS2 ? Help decide.... (25 replies)
  245. Lexus GS300 LS engine Mount kit!!! (22 replies)
  246. Phoenix Area LSX Engine Dyno (0 replies)
  247. hooker mounts (6 replies)
  248. Pontiac to chevy engine mounts (5 replies)
  249. l92 (0 replies)
  250. What is the actual HP of the LS3/480? (39 replies)
