View Full Version : dbw motor, dbc ecm?
overZealous1
10-13-2010, 07:42 PM
have 2008 tahoe 5.3. it is dbw and 58x reluctor. will be doing the 58x to 24x conversion module by lingenfelter, so i can use the fairily cheap aem ecu for the 2000 camaro.
here is the question. it there any chance the aem will interpret the dbw system? i have a feeling i know the answer, no, but would rather have the dbw due to install simplicity.
or, if i just went with the boring ol' stock ecu for the 58x, and dbw, it will save me $1200. BUT, will the stock ecu be able to be finely tuned enough for a twin turbo set up and larger injectors?
if anyone has any good ideas here, let me know.
Mike Norris
10-14-2010, 04:35 AM
I want to say that the AEM will not drive the DBW, but they would be the ones to call to give you the correct answer.
I would still use the 58x ECM whether it is an E38 or E67. The E38's are much more boost friendly and MOST of either ECM can be updated with a 2bar MAP operating system to run a boost vehicle properly.
I would need to have a base HP Tuner file from the ECM to even see if is upgradeable to a 2bar OS.
Hope this makes sense.
Mike Norris
overZealous1
10-14-2010, 09:11 AM
makes total sence mike. i am confused though on the ecu codes. e38 and e67. i will try to do a search to see what vehicles those come in.
i did purchase a 2005 cts throttle pedal, only to find out later i need a tac module also, and they don't have it. i did research last night to see what other vehicles might be compatible with the pedal sensor, but my brain shut off at about 2 hours, hahaha. will start again today. seems 2005 is about the time it could be one of 2 different tac modules.
what is good software for me to use to tune the stock ecm? what is the resolution on the maps? i have used haltech and aem before, but never rewriting a stock ecu myself. how is the interface, and how easy is it to work with?
i have a cut engine harness, so i have all my sensor ends, but no ecu end. so really i could use whatever ecu i wanted.
what would make one ecu more acceptable to running map than another?
overZealous1
10-14-2010, 09:59 AM
after more research, it appears the e38 has mapping for 2bar map. due to the zr-1 and cadillac supercharged applications.
took a look at hp tuners. looks pretty good. priced good too.
overZealous1
10-14-2010, 11:36 AM
thanks again mike for the info over the phone!!
Mike Norris
10-14-2010, 04:41 PM
No problem and let me know what you decide.
Mike Norris
overZealous1
10-15-2010, 08:28 AM
gave john over at speartech a call and we got straightened out the last parts i need. already purchased the parts. 09 vette ecu, 06 vette maf, and 08 vette pedal. sounded like no sweat for them to do the harness. finally feeling comfortable i have all the parts to install with minimal headaches, and run to boot!!
Mike Norris
10-15-2010, 10:27 AM
John is the man for sure and with his packages you can rest assured that it will be correct.
Mike Norris
