View Full Version : LS7 / Z06 Oiling Issues
JEFFTATE
07-11-2011, 10:52 AM
Has anyone heard of any particular LS7 / Z06 oiling issues ?
I know Ron S. recently had an oiling problem and engine failure on his LS7.
And I've heard they have a problem on long left-hand sweepers .
Does anyone know the root cause and solution for this problem ?
Mr.VENGEANCE
07-11-2011, 11:06 AM
i had that on my first LS7.. you made sure the intake and return lines are proper to the pan right?
93Polo
07-11-2011, 11:26 AM
An interesting read here:
http://forums.corvetteforum.com/c6-z06-discussion/2323798-oil-starvation-on-track-hard-data.html
Dreamin has a follow up topic for his LPE tank installation and another for the data logging
parsonsj
07-11-2011, 12:29 PM
Yikes! It seems the LPE oil tank is in my future. The very near future, because I'm going to VIR on the 23rd.
sik68
07-11-2011, 12:33 PM
Yes, I have also read several threads about LS7 oil starvation on corvette forum. Problems started to occur for the z06 crowd when switching over to stickier tires.
Here's a pretty informative synopsis by Avaid:
http://aviaid.com/pdfs/153-boltin_dry_sump_lubrication_systems_for_ls7_engine _and_zo6_corvette.pdf
93Polo
07-11-2011, 12:47 PM
If you have the original design tank I would be looking for an upgrade before hitting the track. I would also look into doing something inside the pan to keep the pickup from pulling in air next. Many interesting ideas and opinions in those topics.
parsonsj
07-11-2011, 12:52 PM
I've got an early '07 that has already had a blown motor replaced under warranty once. I'm looking at the 09 tank (2 more quarts) and the LPE (3 more, but with an ugly welded-on wart on the side).
As far as the pan goes, from what I can see, a left-hand turn actually helps the suction side, so I'm a bit skeptical on the pan mods. I think more capacity is the main fix.
The other thing to look at is if VIR has any long left-hand sweepers (most are right-hand due to clockwise tracks).
Edit: Turn 3 could be a problem....
Mike Holleman
07-11-2011, 06:33 PM
John, I have ridden around VIR in a stock Z06 turning very quick laps with no oiling issues. Don't sweat it. We were turning 2.09 laps. This car runs there regularly with no issues.
Mike
Ron S
07-11-2011, 06:48 PM
VIR won't be a problem, no real long sweepers. The stock oil pan is the issue. My car had a 3 gallon tank, and still blew up. The stock pan will work in conjunction with the Avaid trap door baffling, or the $1580 ARE pan.
