View Full Version : Making your factory gauges work with the LS engines!
redlinegw
05-12-2011, 11:50 AM
Redline Gauge Works can do all the necessary gauge conversions for all you guys and gals doing the popular LS swaps into your vehicles. In most cases we can convert your original speedometer to electronic using AutoMeter internals also amp to voltmeter conversions, temp gauge and oil psi gauge conversions so you can use smaller 1/8 pipe sending units. Our very popular factory tachometer conversions calibrated to 4cylinder spec to work right off your GM computer. Check us out at www.redlinegaugeworks.com (http://www.redlinegaugeworks.com) or give us a call at (661) 259-8891 ask for Shannon or Andy.
Samckitt
05-12-2011, 12:20 PM
Current oil pressure and temp gauges are electric, can they be converted to use the same signal as the LS sending unit / PCM provides so a multiple sending units are not needed?
Gauges look like:
newvintageusa
05-18-2011, 02:46 AM
Gauges don't care what they are connected to, as long as you are using the proper senders, you cannot go through the PCM. You dont want to anyway as the factory instrument outputs are really not accurate.
Mark
Samckitt
05-18-2011, 05:09 AM
Mark
I agree, trying to figure out how to hook it all up without having 2 oil pressure sensors, 2 temp sensors, one for PCM one for gauges.
