View Full Version : PS pully interference with stock Gen 1 Camaro subframe.
BuddyP
01-04-2011, 01:22 PM
setting a LS motor with C5 accessories into a stock Gen 1 Camaro frame. Power steering has interference. Anybody deal with this? Is a smaller pully available? What did you do to clear this?
Or is my only option to get LS1 bracketry and swap the alt. and PS around?
How much is it interfering Buddy? I had a customer of mine come up with a solution for his 65 vette. He found a pulley through Summit that only needed minor machining to fit onto the pump as needed and the pulley was a smaller diameter. he reported no issues with the pump working. That's not surprising though as it's spinning faster now.
garys 68
01-04-2011, 11:12 PM
I saw this on another board, Summit SUM-340203. 5" diameter, 0.664 ID vs the vette 0.67 ID.
CarlC
01-05-2011, 07:42 AM
What motor mounts and adapter plates are you using?
BuddyP
01-06-2011, 07:33 AM
stock poly motor mounts, can't remember on the adapter plates.
Concept One Pulleys
02-08-2011, 11:49 AM
How much interference are you encountering?
We deal with this on a daily basis and would be happy to help you out. We specialize is custom-fit needs (aka "interference").
K.R.
Concept One Pulleys
LS Chevy Victory Series Pulley Systems (http://c1pulleys.com/lschevyvictoryseries.html)
Made in the USA
CamaroAJ
02-08-2011, 03:57 PM
buddy and i are swapping our front drive set up. mine fits his car his fits my car.
andrewb70
02-08-2011, 05:07 PM
http://www.ls1tech.com/forums/conversions-hybrids/1007602-body-6-0-5-3-ford-p-s-pulley-swap-pics.html
