View Full Version : Oil pickup tube girdle: gauging intereste before I have them made
Samckitt
05-12-2011, 12:13 PM
I have been debating on making some of these oil pickup tube girdles. It uses a bolt on both sides of the tube to equalize clamping force to insure tube is straight & o-ring stays in proper location. Was thinking $15.00 shipped. Comes with the girdle & 2 bolts.
https://static1.pt-content.com/images/pt/2011/05/LS_OILPUMP_GIRDLE2-1.jpg
https://static1.pt-content.com/images/pt/2011/05/LS_OILPUMP_GIRDLE-1.jpg
If I can get 25 of them sold I will have them made.
Samckitt
01-29-2012, 06:31 PM
Even though I got very little response on my initial thread, I decided to make some anyway.
This is the first one I assembled recently. I had to do too much sanding on it to fit, so going to redesign my part & have some cut again.
Chevelle598bb
02-06-2012, 11:15 AM
I'll take one Scot when you get them finalized.
Samckitt
02-06-2012, 04:54 PM
OK, sounds good. I'll get one together for you.
PM me, your inbox is full.
Scot
daytonayellaz
02-08-2012, 08:58 AM
I guess I missed your initial thread. Put me down for a few of them.... I will start offering them with my drop out engines when I do the Mast oil pan swaps for the prospective buyer. :cheers:
Twentyover
02-08-2012, 10:18 PM
Does this solve a known problem?
Samckitt
02-09-2012, 09:54 AM
A post about them on LS1ttech:
It's mainly a piece-of-mind type of thing. I agree that if you install the tube properly, this really isn't necessary, but on the other hand, combined with all of the other "piece of mind" things I pissed money away on, every time I stomp on the motor, I can be confident that the motor isn't going to self destruct.
And, like others have said, after the tweaking I needed to do on my pickup tube, I was glad that I had a collar keeping the oil pump end where it belongs while I was reefing on the other end.
BulldawgMusclecars
02-15-2012, 08:03 PM
Brp has made a similar girdle for years; you might want to be sure it isn't patented before proceeding.
censo69
02-19-2012, 11:29 AM
Are the available ?
Samckitt
02-19-2012, 05:39 PM
I have stuff to make some, none ready today. Takes me about half an hour to make one.
LSxChevelle
02-21-2012, 05:49 PM
1/2 hr @ min wage? :)
Samckitt
02-21-2012, 06:33 PM
Barely!
censo69
02-22-2012, 06:07 PM
Do you have a pic of the final design ?
CreepinDeth
02-29-2012, 03:49 AM
......on the engine?? That would help sell it.
Samckitt
02-29-2012, 08:04 AM
I'll try and get some here soon. Been fighting being sick, family sick, a truck with busted break lines, & too much other bad luck to go into.
Samckitt
03-11-2012, 08:34 AM
Have a handful done. I used the original ones I had cutout. Had to grind & file on them to get them to work. Next ones (If I make more) I will change some dimensions so less grinding is required. Couldn't get pic of it on the pump as my motor is in the corner of the garage behind a bunch of stuff at the moment.
analyte
03-11-2012, 03:17 PM
I'd take one of those too. I like the piece of mind aspect....
Samckitt
03-11-2012, 03:32 PM
I have 4 of them ready to go. PM Me.
Ls1camaro69
12-08-2013, 04:15 PM
Are you still making these or have one available to buy?
Samckitt
12-08-2013, 06:42 PM
Initially I made a dozen or so. Wasn't a big demand for them so I didn't make more. I think they are all gone but I may have one laying around. I'll look but I doubt I have any left.
Ls1camaro69
12-09-2013, 06:07 PM
No problem. Let me know if you find one...if not I'll order one of the $25 ones
