View Full Version : Corvette fuel filter question.
TnBlkC230WZ
04-10-2011, 02:11 PM
Can you use 3/8 rubber hose and hose clamps on the c5 corvette filter?
CarlC
04-10-2011, 03:14 PM
Not recommended. The ends are smooth and not intended for use with rubber hose (barbed ends).
67zo6Camaro
04-10-2011, 09:03 PM
and to add to that, if you are running the fuel injection of an LS type motor it runs at 65psi.
garys 68
04-11-2011, 04:11 AM
Russel and others make a 5/16" and 3/8" quick disconnect fittings. The pump puts out a lot of pressue to the 3/8", but you can use a hose clamp on the 5/16" return.
https://static1.pt-content.com/images/pt/2011/04/DSCN0335-1.jpg
TnBlkC230WZ
04-11-2011, 06:09 AM
Thanks Garys 68, that is the fitting I need. I have the -6 adapter on the return side, but there isn't room on the filter for two -6 adapters. So I'll get one of those 3/8 fittings for the supply side. I bought one of the plastic hoses, but needed several adapters to hook it to the fuel tank.
garys 68
04-11-2011, 07:04 AM
The 5/16" quick disconnect to 5/16" hose barb return line fitting #730-4926 napa, or dorman 800-120
