View Full Version : 4.8 Swap?
thirdstreettito
04-18-2011, 02:51 AM
I did a search, "No search results." Has anyone done it? I dont see why not, you can get the 4.8 on the cheap, its got 270hp+ and with a turbo/supercharger it can do an easy 400hp+. So, has anyone done this? Any comments? Thanks, Bradley
garys 68
04-18-2011, 04:29 AM
I'm assuming you're referring to the GM 4.8, 5.3, 6.0 series iron truck motors. I'm doing a 5.3 in a 72 cutlass now. Pretty much anything that applies to the 5.3 and 6.0 swaps will work for the 4.8. The 4.8s are really cheap but the 5.3s are about the same price and are available everywhere.
thirdstreettito
04-18-2011, 08:46 AM
Yeah, just wondering if anyone has done a 4.8 swap.
Nessumsar
04-18-2011, 09:22 AM
I don't see why; the 5.3 will be the same price (unless you already have the 4.8), and will make more power with the same mods. A T70 turbo, cam/springs, and injectors will put you over 500 hp.
dontlifttoshift
04-18-2011, 09:48 AM
400 plus hp is a camshaft and springs away with a late 5.3, way easier than a turbo and definitely cheaper in the long run.
thirdstreettito
04-18-2011, 10:11 AM
I like the mileage of a 4.8 though...
garys 68
04-18-2011, 01:54 PM
LOL, that's what I say about going with the 5.3 instead of a 6.0 or 6.2. But hey, a 455 would get less than 10mpg, so anything is better than that for a DD.
6'9"Witha69
04-18-2011, 02:37 PM
The milage difference b/w a 4.8 and a 5.3 is laughable. Get a 4.8 and put in a 5.3 crank. This makes a higher compression 5.3. Cam and springs and your done. 400-450 HP easy.
thirdstreettito
04-18-2011, 04:36 PM
Darn you tall man. Darn you. What kind of compression we talking? From what to what?
garys 68
04-19-2011, 05:17 AM
You got me curious, so I looked up the milage ratings on a 4.8 vs 5.3 in the same vehicles. Best increase with the 4.8 was 1mpg city, and most highway ratings were the same for the two.
The 4.8 and 5.3 share the same bore size. The longer stroke of the 5.3 will have more noticable torque. Go with the 5.3. My 05 with under 50k miles, accessories, harness, ecu, pedal, pump, etc and a 6 month warantee was under $900, shipped to me.
thirdstreettito
04-19-2011, 07:08 AM
Thanks. 6'9"Witha69 still waiting for a compressions answer. :)
6'9"Witha69
04-19-2011, 07:28 AM
IIRC it goes up to ~ 10.0-10.2:1. I would have to confirm with the buddy who did it exactly what it was. Reason being that the 4.8 has flat top pistons and the 5.3 uses dished, so OEM they have the same compression ratio despite their disparate displacments.
thirdstreettito
04-19-2011, 07:49 AM
Wait, the 4.8 stock has a 10:1 CR? Is the .2 worth it?
garys 68
04-19-2011, 07:51 AM
Just a personal note on CR in these motors and some real life experience. The 5.3 and 4.8 have a 9.5:1 and run great on regular gas. My LQ9 with 10.1:1 CR reccomends premium. If I run regular in it, I can feel when the knock sensor trigger timing retard. I've heard from others the same thing and that the spark retard results in worse milage.
If your goal is economy, raising the CR might be counterproductive in addition to the cost of the crank, rods, etc.
THE TECH
04-19-2011, 09:24 AM
Just finishing up a 5.3 in a Nova. Should be a fun little ride.
68Formula
04-19-2011, 05:27 PM
Plus the OP mentioned a turbo/supercharger, so raising it more than stock is pushing beyond pump gas. Sounds like the ideal might be a stock 4.8L or 5.3L with a takeout camshaft from an LS2 and small single turbo would be a good combination fuel economy/power/cost effectiveness.
Nessumsar
04-20-2011, 08:06 AM
The easiest way to make big power with a 5.3 is to run an early LS6 Z06 camshaft and springs, a t70 (or equivalent) turbo, intercooler, injectors, and maybe some water/meth for safety. That will put you near 550whp.
thirdstreettito
04-20-2011, 08:40 AM
Yeah, but I want to keep good mileage. A T56 will be behind the LS.
Nessumsar
04-20-2011, 10:34 AM
With a good tune you'll get better than stock mileage, if you can keep your foot out of it. :)
thirdstreettito
04-20-2011, 10:44 AM
Still have the power?
FWIW, I'm pretty much in the same situation as you. I wrote an earlier reply to you, went to post it here and it evaporated into the ether,(WT....!), so here is my truncated version. I plan on swapping an LS-something into my 77 Lemans wagon. I dismissed the 4.8 initially as being too puny. Saw some clips on YT of 4.8's racing 5.3's and was totally impressed with the 4.8's. Did some snooping around and ended up at Thirdgen.org. There is a wealth of swapping info there so have a look. Also, there is discussion specifically on 4.8 swapping. I would now jump on a 4.8 for my swap if one crosses my path for a good price. Add cam, intake and headers and, from what I've observed, you end up with a spunky little screamer. The 4.8's seem like a low-buck entry into the LS world to me, and they offer some pretty impressive output plus excellent gas mileage. Once you've sampled that you always have the option of stepping up later to something larger. I'm a big fan of getting the most bang for the least buck. Keep us informed on your choice and project. Sounds cool!
Gavin.
Nessumsar
04-20-2011, 11:55 AM
Thats the beauty of forced induction!
