T_Raven
02-25-2011, 11:22 PM
I'm putting an LS1 and t56 into an 89 Trans Am. I've also got a t56 to put into my 67 later on. I also have an 01 TA so I'm on ls1tech quite a bit. There are a lot of threads over there about the stock 4th gen clutch master cylinders not moving enough fluid especially if you have a stiffer than stock clutch. My 01 shifts like crap but it might need a clutch. The Tick Performance master cylinder is a pretty popular upgrade for 4th gens. It's just a Tilton master cylinder with a machined adaptor to put it at the correct angle and an adjustable rod.
http://www.tick-performance.com/tickshift/parts/ls1fbody/hydraulics/#master
Check out the remote bleeder at the bottom of that page. Looks like it would be a nice thing to have for any t56 with a hydraulic clutch.
Most swaps I've seen on here are using stock 4th gen clutch master cylinders with the little angled plate behind the brake booster, so I could easily use one in both of my cars, but I don't want to mess with a stock master since they obviously aren't adequate in the first place.
I emailed Tick Performance to see if their master cylinder will work in my 89. I don't see why it wouldn't unless there's just not room for it, the machined aluminum piece looks a little wider. But even if it does it seems a little redundant to have an adaptor plate on the firewall and an adaptor on the master cylinder. It would probably be easy enough to buy a tilton master and make an adaptor to put it at the angle it would need to be at.
For those using a stock 4th gen master how satisfied with it are you?
And for those not using a stock 4th gen master what are you using?
Thanks in advance
Thanks in advance
