67zo6Camaro
01-02-2011, 07:02 PM
I did a cam change search on this site and read several post. From this I came up with a suggested cam change for my stock 2001 LS6 motor. Also I got a cam suggestion from Comp Cams tech center. Basically Im looking for any additional comments and/or suggestions related to my pursuit for more HP.
I currently have a 2001 LS6 motor in a 67 Camaro. I run a T56 trans to a 9" with 4.11 gears. I have upgraded the throttle body to an 80mm BBK, I use the Street and Performance shorty headers that go to a 2.5" dual exhaust with a cross-over and only one set of O2 sensors. The ECM is a 98 Camaro style that was programed by S & P.
My last dyno showed only +-375 rear wheel HP which is about +-425ish HP at the flywheel. I would love to max out this motor by using a cam, spring and push rod upgrade only this time around. The car is used for autocross and track days, therefore, the RPM range is 2000 to 6500. I do run a P/S pump and power brake. I know a re-programe of the ECM is a must after the cam install.
Here is what I got as a suggested cam from the prior post: a 224/230 114 LSA at .581 and .592 or a 224/224 upto a 228/228 116 LSA at .571 and .571.
Here is what was suggested by the Comp Cams tech center: with a duration of .050, cam is a 223 intake and 231 eshaust with .610 lift intake and .617 exhaust on a 112 degree lobe separation angle.
Cam #54-457-11
Dual spring kit #26926TS-Kit
Pushrod set #7955-16
Im not sure what power anyone of these combo's will make, but I would like to hear your comments.
Brett
Cam #54-457-11
Brett
