analyte
03-20-2011, 01:06 PM
I'm looking for an LQ4 or LQ9 to install in my 66 Chevelle, but I have a few questions to narrow what I'm looking for. I have no interest in a alum block as I'm after the torque of the 6.0 since I'm swapping out a BBC 454.
Should I be looking for a long block or a complete engine with all access?
I'll be using corvette brackets most likely based off install research with an LS1/2 intake, but are the access the same for all engines; i.e. a/c comp, alt, pwr steering pump so that I may reuse with diff brackets?
At what point should I consider re-ringing a block or rebuilding? 100K? 125K? 150K?
I'm seeing a lot of engines from 100K to 150K, but I'm unsure if they're just broke in by that time or not? Comments, experience?
The only mod will be a cam swap at this time with an LS1/2 intake (Possibly an LS7 cam if it will work)
When is a LQ9 a better deal than a LQ4?
I'm seeing LQ4 long blocks for about 800-1000 depending on miles and whether it's out of a van or truck.
Does van or truck matter since intake/brackets won't be used?
I'm seeing LQ9 complete engines for around 1400-1600 out of Caddy;s or SS trucks.
Is it worth 4-500 more to get the LQ9 with the higher compression? Does it open up more cam options or make the LS7 cam a better fit?
I want to keep the engine purchase under 2000 with tax, but I want to get the best deal possible. For the top of my budget, I'd like all sensors, access if usable, and injectors.
I'm ok with used engines as long as they have a warranty, but I'm unsure what PM to do based on the miles it has? rings? bearings? etc
Thanks for the help and sorry for the questions. There is a lot to take in regarding LSx engines.
Kerry
Kerry
