View Full Version : Automatic Transmissions
Pages : [1] 2 3 4 5
  1. I need a measurement on a Lokar 4L70E/4L60E dipstick (6 replies)
  2. 4L60E Tuning for Autocross and Track Days (0 replies)
  3. 6l80 Shifter options (1 replies)
  4. 700r4 What Transmission Company (6 replies)
  5. solution for mecanical speedo wirh 4L80e (5 replies)
  6. How to "unlock" 700R4 convertor without "ported" vacuum?? (5 replies)
  7. Converter advice (4 replies)
  8. Transmission won't shift? (1 replies)
  9. OPINIONS WATED on 700R4 LOCK-UP verses NON LOCK-UP (6 replies)
  10. 68 Camaro Trans recomendation (6 replies)
  11. Transmission Swap Question (6 replies)
  12. 4l80E banjo fittings (3 replies)
  13. 4L65E Only works when cold 200-300' (3 replies)
  14. Shifter recommendations (3 replies)
  15. Transmission cooling lines hard/braided (6 replies)
  16. 400 turbo Gear Vendors OD (1 replies)
  17. 200R4 or 700R4? (7 replies)
  18. 4l80e Torque Convertet installed correctly? (3 replies)
  19. 700r4 (4 replies)
  20. Lokar ESS question (3 replies)
  21. 4L80e front leak issue help…looking for a good shop (5 replies)
  22. 4l80e Lube problem (2 replies)
  23. 1970mustang 351c (1 replies)
  24. C7 transaxle in C5 Corvette (7 replies)
  25. 4L60 vs 4L80 (3 replies)
  26. TORQUE Converter Recommendation help (4 replies)
  27. 4l80 swap dipstick options (8 replies)
  28. 4l65e shift pressures and steady state pressures (11 replies)
  29. Gen V LT/8l90 tap shift question (1 replies)
  30. 8L90 Tap Shifter (5 replies)
  31. Sport Shifters for 6LXX transmissions (2 replies)
  32. 4l60e question (2 replies)
  33. Transmission Leak (1 replies)
  34. TC lock up (2 replies)
  35. BBC and 4L80E Adapter (0 replies)
  36. Transmission filter to pan clearance (1 replies)
  37. hidden costs installing 4L80 transmission in non computer non LS motor (4 replies)
  38. 700r4 transmission problems (0 replies)
  39. 2005 4l65e rebuild help (5 replies)
  40. 69 Camaro TH350 to 4L80E swap - Cam, Converter stall and cruise specs (6 replies)
  41. TCI Paddles AND TCI Outlaw w/ bump switches interchangeable use via EZ TCU? (0 replies)
  42. TCI 6X, no electronic engine braking (2 replies)
  43. Lt4/10L90 (1 replies)
  44. Low gear driving (1 replies)
  45. Reprogram? (1 replies)
  46. High stall converter, overdrive low RPM (5 replies)
  47. My 8HP70 swap. (26 replies)
  48. Paddle shifting a 4L80E with a GM computer? Can it be done? (4 replies)
  49. Lokar LED Boot Indicator & Sensor kit (2 replies)
  50. Transmission Cooler (5 replies)
  51. TH 350 with lockup (0 replies)
  52. Twist Machine Paddle Shifter (6 replies)
  53. 6l80 transmission shifting issues (1 replies)
  54. Cooler Hose? (11 replies)
  55. 6L/8L Programming w/ ZL1-like Performance (1 replies)
  56. 4L80e Shifting (4 replies)
  57. paddel shifter 4L80 (3 replies)
  58. Dexron (1 replies)
  59. 4L60e tuning (8 replies)
  60. 5th gen camaro shifter on 4L60e (2 replies)
  61. 6L90E transmission controller help! (3 replies)
  62. B&M super cooler trans cooler (2 replies)
  63. 4L80E vs 6L80E - Are two extra gears worth it? (10 replies)
  64. Can someone help me set the kickdown cable on my 700r4? Used a TCI universal cable (2 replies)
  65. Custom Automatic Transmission Shifter Cable Source (1 replies)
  66. Performance automatic vs. dyanamic racing transmissions for max effort C4? (3 replies)
  67. 6l80e Shifter options (7 replies)
  68. Just put in a 8-speed transmission into my 2nd gen.. (1 replies)
  69. 700R4 Hard Shift (2 replies)
  70. Delayed turbo 400 shifting (1 replies)
  71. Need Help: 1992 700r4 into a 67 El Camino 400SBC. What do I need to not burn it up? (7 replies)
  72. Full manual 4L80E (2 replies)
  73. Ideas...How to Shift a 4L80E (1 replies)
  74. TH-350 Shifter Question - Alignment is "off" (1 replies)
  75. 70 Camaro, LSA ... which trans? (11 replies)
  76. Cross member for 4L80E in a 67 (1 replies)
  77. L92 6l80e (10 replies)
  78. Paddle Shifting Opinions (0 replies)
  79. Need shorter Dipstick/tube for my 4L60 transmisison LS swap in Gen 1 Camaro (5 replies)
  80. new trans time...what would you do? (10 replies)
  81. Paddle Shifters ? (6 replies)
  82. How do I hookup my 2004R to my Holley ultra street avenger? (4 replies)
  83. drive shaft yoke options for 6l80 (3 replies)
  84. Help Please....4L70E Behind BB Chevy (2 replies)
  85. Transmission temp sensor location- need help (2 replies)
  86. Need a modern automatic for my 69 Firebird (4 replies)
  87. Hurst Dual Gate + 4L60E? (6 replies)
  88. Did I just kill my 200-4R (5 replies)
  89. 4l85e (2 replies)
  90. 6l80e rear mount cooler (2 replies)
  91. Whats your stall rear gear combo? (10 replies)
  92. 2004R Transmissiln Vendor (1 replies)
  93. th400 to lt4 (2 replies)
  94. need help deciding between 6 or 8 speed auto trans. (0 replies)
  95. A few 4L80E Questions - Shifters and Compatability Help! (12 replies)
  96. 8l90e first gen camaro? (0 replies)
  97. 4L60 or 700R4 (2 replies)
  98. 4l80e smal question help required please (5 replies)
  99. TH350 transmission vs 168T flexplate - clearance issues (1 replies)
  100. 4l80e help required please (8 replies)
  101. TCI 6X in a 68 Chevelle (2 replies)
  102. 4L80E Torque converter is a triple disc noisy (3 replies)
  103. 6l80 in a 2nd gen, anyone done the swap? (5 replies)
  104. EZ-TCU opinions? (1 replies)
  105. 4L75E in the 48 Hour Camaro (9 replies)
  106. Paddle Shifters compatible with factory GM ECU? (2 replies)
  107. 6L80E with column shift (5 replies)
  108. stand alone transmission controller (5 replies)
  109. Lokar shifter buzzing, common problem, quick fix that worked for me (0 replies)
  110. Transmission builders???? (5 replies)
  111. Any 727 or 46RH experts around ? (1 replies)
  112. Newly installed 200-4r is leaking (6 replies)
  113. 4l80e rebuild - what does it need? (3 replies)
  114. 4l70e shift points. (1 replies)
  115. 4L80e into a 69cutlass (12 replies)
  116. "naked" flywheel ??? (6 replies)
  117. 6L80/6L90 rear end gearing (2 replies)
  118. Holley Terminator/Dominator controlling a Twist Machine Paddle shifter (4 replies)
  119. Lokar Shifter Size (0 replies)
  120. 4l85 shift lever question (3 replies)
  121. 2004R instal (6 replies)
  122. What is everyone using for automatic shifters? Post up a pic if it's Cool... (11 replies)
  123. Manual Valve Body (11 replies)
  124. 4l80 questions (1 replies)
  125. Houston Area 4L80E builders? (8 replies)
  126. Transmission carnage (1 replies)
  127. Torque converter rec (or manual swap?) (2 replies)
  128. Automatic Transmission help - Corvette Transplant (0 replies)
  129. 4L60E Crossmember mounting location from centerline (1 replies)
  130. Zf 8hp70 mated to sbc (65 replies)
  131. ZL1 10 speed aftermarket cersion? (2 replies)
  132. 4l80e highperformance (4 replies)
  133. Trans cooler sizing (3 replies)
  134. Question on selecting a converter. (5 replies)
  135. 2004r (8 replies)
  136. Hose heat shield question (2 replies)
  137. Th400 to 2004r question (2 replies)
  138. anyone know the thread and bolt size for 60's gm tranny mount? (3 replies)
  139. engine braking and better downshifts with a 700R4/4L60 (0 replies)
  140. Torque converter (4 replies)
  141. 5th gen Camaro automatic trans linkage pic? (0 replies)
  142. Which torque converter stall speed should I choose (4 replies)
  143. TCI 6 Speed Automatic (1 replies)
  144. Help with 200r4 install 1967 Gto (4 replies)
  145. 200r4 install time on 67 Gto? (0 replies)
  146. 67 Mustang Coupe. (0 replies)
  147. Torque converter and flex plate question (0 replies)
  148. What would my rear gear theoretically change to when swapping trannys? (2 replies)
  149. 3.73 gears in 700R4 ? (13 replies)
  150. 1979 ls swap with 4l60e (2 replies)
  151. Paddle shifters and gear indicators for 4L85E transmission (6 replies)
  152. 4L80E guys - what dust cover are you running? (5 replies)
  153. 200r4 or 700r4 (10 replies)
  154. 6l80e in 67 gto with original poncho v8 (0 replies)
  155. what brand master kits for Th350 hold up to storage best? (0 replies)
  156. Rear Mounted Trans Cooler Ideas (6 replies)
  157. Gen 1 Camaro Planning (4 replies)
  158. 4L80E in a 67 Camaro...dipstick??? (0 replies)
  159. 6 speed automatic, here I come (1 replies)
  160. 4L80E install in a first gen camaro (16 replies)
  161. 4L65E....best way to split the VSS signal?? (0 replies)
  162. Stand alone? Desperate for a solution. (18 replies)
  163. LS3 416 with 6L80E or T56 Magnum (18 replies)
  164. Clutchless sequential shift for T56? (10 replies)
  165. 1966 Chevelle LS3 engine swap with 5L40-E automatic transmission (1 replies)
  166. dual action shifter >> good for drifting? (0 replies)
  167. TH400 flex plate gap (1 replies)
  168. Reputable place to get a used low mileage 4L80E? (0 replies)
  169. Transmission choice. (0 replies)
  170. Opinions on 4L80E converted 6-speed automatics (22 replies)
  171. 6L80E Inspection (4 replies)
  172. T56 Magnum & LSX Block (4 replies)
  173. Need help with 4l60e lock up (2 replies)
  174. OD Auto for stockish 1967 A body (Chevelle) (7 replies)
  175. Tranny recommendation (2 replies)
  176. Transmission control module help (2 replies)
  177. Early SBC with a 4L60E Question (1 replies)
  178. OD Tranny options (17 replies)
  179. Temp sensor (2 replies)
  180. 4l80 in 2nd gen camaro fitment (0 replies)
  181. 4L60e experts needs some help / advice on dipstick fittment (7 replies)
  182. SFI Bell Housing Flywheel Cover (1 replies)
  183. 4L70E controller options (2 replies)
  184. 8L90 Fit a LSA engine (6 replies)
  185. HP loss through transmission (4 replies)
  186. 4l80e TCC lockup options (9 replies)
  187. TH350 deep expertize needed! (0 replies)
  188. 4L60E Dipstick selection (2 replies)
  189. th400 where to buy? (2 replies)
  190. 68-72 A Body 4L80 Crossmember (5 replies)
  191. 4l80e transmission in 1967 gto (3 replies)
  192. 6L80E G8 Trans Controller (11 replies)
  193. Rearend gear ratio (1 replies)
  194. C4 trans does not shift after blower install (0 replies)
  195. new 4L65E shift flare (0 replies)
  196. 4R70W transmission question (1 replies)
  197. Help with transmission noise diagnosis! (8 replies)
  198. Auto trans. Help please! (4 replies)
  199. TH400 vent tube (0 replies)
  200. 4L60E or not? I.D. help (7 replies)
  201. Cross member 4L85E trans 1969 camaro. (1 replies)
  202. 4l80E Transmission controller advice suggestions (3 replies)
  203. 6L90E oil pan selection (6 replies)
  204. stand alone transmission controller vs ls1 pcm (5 replies)
  205. torque converter question (0 replies)
  206. where do I cut? (6 replies)
  207. TH400 shifter suggestions??? '67 Firebird 400 coupe for Auto-X'ing. . . (5 replies)
  208. Mopar TF904 HELP (7 replies)
  209. 97 S-10 4L60E behind a 04 LQ4? (0 replies)
  210. best trans to use in c10 (4 replies)
  211. Auto for autocross? (3 replies)
  212. auto overdrive tranny in DFW (8 replies)
  213. 4l80 swap into first gen (4 replies)
  214. Th400 (0 replies)
  215. Trans suggestions for 2nd gen Ls3 Firebird ... (9 replies)
  216. shiftworks binding (2 replies)
  217. Automatic shifter in a 67 Camaro console (1 replies)
  218. NEED HELP 2011 CTS-V 6l90 TRANS MOUNT ?? (2 replies)
  219. TH350 shifting issue (0 replies)
  220. School Me on Torque Converters (4 replies)
  221. 4L80E shifter options? (9 replies)
  222. Domestic dispute with my 700R (9 replies)
  223. TV cable HELP! (6 replies)
  224. Chances of blowing an original transmission in 69 Cougar (1 replies)
  225. phoenix transmission 4l80e (7 replies)
  226. 4l60e id (5 replies)
  227. 200 r4 will not lock up in fourth gear ( B&M controller ) (2 replies)
  228. Transmission 4L60E (7 replies)
  229. 2004r won't go new thread (5 replies)
  230. just finished the tried to back out of garage and tire chirps and it dies. (6 replies)
  231. Velocity/ridetech Camaro (1 replies)
  232. Help With Speedo Cable (1 replies)
  233. TH400 Users..... (5 replies)
  234. turbo 400 pickup tube (1 replies)
  235. Bellhousing failure, BIG failure... Opinions? (3 replies)
  236. Starter, Flex Plate Help (7 replies)
  237. A/C Delco parts catalog (2 replies)
  238. What transmission for 572 Hemi? (17 replies)
  239. Lokar shifter adjuster plug (2 replies)
  240. torque converter (1 replies)
  241. Pontiac 400 trans options (2 replies)
  242. 4L60e help (0 replies)
  243. 750hp TH350 (6 replies)
  244. 2004r tv cable question (0 replies)
  245. gear vendor help (1 replies)
  246. Hard shift from 1st to 2nd HELP (2 replies)
  247. Trans fluid (4 replies)
  248. manual 4l80e? (9 replies)
  249. 10 camaro shifter for a 4l65? (2 replies)
  250. Second gen camaro 4l80e crossmemeber? (3 replies)
