    Results 1 to 5 of 5
      Mar 2013
      Sunny Calif
      TORQUE Converter Recommendation help
      HELP!,
      Built 4l80e with below listed parts, question, which torque converter? 3.73 gears, 26" od tires.
      4000lb 68 Camaro with full tank and driver, cuz we be fattys
      LS3 (377cu in), Whipple 2.9, BTR PDS Stg II 227/242 .614"/.592" 122+6 Cam, hp goal 600+ rwhp on E85
      Options: Yank LS power adder series single disc 3400 stall or Circle D Pro Series 258mm Triple 3Disc 2800-3000 stall - both with lock up.
      Sonnax Smart-Tech Overrun Clutch Valve Kit PN# 34200-40K
      McLeod Performance Automatic Transmission Rebuild Kit PN# 88075K
      BowlerTransmissions 300M Hardened Input Shaft PN# TCS HP-4L80E-35
      May 2015
      I would go with a Circle "D" I have not heard one bad thing about them.
      3400 stall would be too much stall for your combo IMO.
      Nov 2016
      Sulphur, La
      Circle D is great. I ripped one in half and had a flash fire. Chris the owner did everything correctly to rectify my situation.
      May 2015
      I bought a 245 MM ( 9 3/4") triple disc 3600 stall from Circle "D", but mine is not running yet.
      I need the higher stall because I am only using an inline 250 6 cylinder for my power plant.
      Mar 2013
      Sunny Calif
      Yank vs. Circle d.
      Well after almost dying in 2022 due to china virus hospitalization I'm back on track and but still on the fence after so rudely being interrupted.
      Circle D rep recommended a 2800-3000k stalled pro series
      Diameter 10.25"(258mm) triple disc, lock up.
      Emailed tech support at yank and no one got back to me so is what it is, was looking at their S/C Series 3000 stall 10.5" o.d. lock up.
      Anyone care to chime in with experience on this application?
