- Lokar shifter adjuster plug
- What transmission for 572 Hemi?
- A/C Delco parts catalog
- Starter, Flex Plate Help
- Bellhousing failure, BIG failure... Opinions?
- turbo 400 pickup tube
- TH400 Users.....
- Help With Speedo Cable
- Velocity/ridetech Camaro
- just finished the tried to back out of garage and tire chirps and it dies.
- 2004r won't go new thread
- Transmission 4L60E
- 200 r4 will not lock up in fourth gear ( B&M controller )
- 4l60e id
- phoenix transmission 4l80e
- Chances of blowing an original transmission in 69 Cougar
- TV cable HELP!
- Domestic dispute with my 700R
- 4L80E shifter options?
- School Me on Torque Converters
- TH350 shifting issue
- NEED HELP 2011 CTS-V 6l90 TRANS MOUNT ??
- Automatic shifter in a 67 Camaro console
- shiftworks binding
- Trans suggestions for 2nd gen Ls3 Firebird ...
- Th400
- 4l80 swap into first gen
- auto overdrive tranny in DFW
- Auto for autocross?
- best trans to use in c10
- 97 S-10 4L60E behind a 04 LQ4?
- Mopar TF904 HELP
- TH400 shifter suggestions??? '67 Firebird 400 coupe for Auto-X'ing. . .
- where do I cut?
- torque converter question
- stand alone transmission controller vs ls1 pcm
- 6L90E oil pan selection
- 4l80E Transmission controller advice suggestions
- Cross member 4L85E trans 1969 camaro.
- 4L60E or not? I.D. help
- TH400 vent tube
- Auto trans. Help please!
- Help with transmission noise diagnosis!
- 4R70W transmission question
- new 4L65E shift flare
- C4 trans does not shift after blower install
- Rearend gear ratio
- 6L80E G8 Trans Controller
- 4l80e transmission in 1967 gto
- 68-72 A Body 4L80 Crossmember
- th400 where to buy?
- 4L60E Dipstick selection
- TH350 deep expertize needed!
- 4l80e TCC lockup options
- HP loss through transmission
- 8L90 Fit a LSA engine
- 4L70E controller options
- SFI Bell Housing Flywheel Cover
- 4L60e experts needs some help / advice on dipstick fittment
- 4l80 in 2nd gen camaro fitment
- Temp sensor
- OD Tranny options
- Early SBC with a 4L60E Question
- Transmission control module help
- Tranny recommendation
- OD Auto for stockish 1967 A body (Chevelle)
- Need help with 4l60e lock up
- T56 Magnum & LSX Block
- 6L80E Inspection
- Opinions on 4L80E converted 6-speed automatics
- Transmission choice.
- Reputable place to get a used low mileage 4L80E?
- TH400 flex plate gap
- dual action shifter >> good for drifting?
- 1966 Chevelle LS3 engine swap with 5L40-E automatic transmission
- Clutchless sequential shift for T56?
- LS3 416 with 6L80E or T56 Magnum
- Stand alone? Desperate for a solution.
- 4L65E....best way to split the VSS signal??
- 4L80E install in a first gen camaro
- 6 speed automatic, here I come
- 4L80E in a 67 Camaro...dipstick???
- Gen 1 Camaro Planning
- Rear Mounted Trans Cooler Ideas
- what brand master kits for Th350 hold up to storage best?
- 6l80e in 67 gto with original poncho v8
- 200r4 or 700r4
- 4L80E guys - what dust cover are you running?
- Paddle shifters and gear indicators for 4L85E transmission
- 1979 ls swap with 4l60e
- 3.73 gears in 700R4 ?
- What would my rear gear theoretically change to when swapping trannys?
- Torque converter and flex plate question
- 67 Mustang Coupe.
- 200r4 install time on 67 Gto?
- Help with 200r4 install 1967 Gto
- TCI 6 Speed Automatic
- Which torque converter stall speed should I choose
- 5th gen Camaro automatic trans linkage pic?
- Torque converter
- engine braking and better downshifts with a 700R4/4L60
- anyone know the thread and bolt size for 60's gm tranny mount?
- Th400 to 2004r question
- Hose heat shield question
- 2004r
- Question on selecting a converter.
- Trans cooler sizing
- 4l80e highperformance
- ZL1 10 speed aftermarket cersion?
- Zf 8hp70 mated to sbc
- 4L60E Crossmember mounting location from centerline
- Automatic Transmission help - Corvette Transplant
- Torque converter rec (or manual swap?)
- Transmission carnage
- Houston Area 4L80E builders?
- 4l80 questions
- Manual Valve Body
- What is everyone using for automatic shifters? Post up a pic if it's Cool...
- 2004R instal
- 4l85 shift lever question
- Lokar Shifter Size
- Holley Terminator/Dominator controlling a Twist Machine Paddle shifter
- 6L80/6L90 rear end gearing
- "naked" flywheel ???
- 4L80e into a 69cutlass
- 4l70e shift points.
- 4l80e rebuild - what does it need?
- Newly installed 200-4r is leaking
- Any 727 or 46RH experts around ?
- Transmission builders????
- Lokar shifter buzzing, common problem, quick fix that worked for me
- 6L80E with column shift
- Paddle Shifters compatible with factory GM ECU?
- 4L75E in the 48 Hour Camaro
- EZ-TCU opinions?
- 6l80 in a 2nd gen, anyone done the swap?
- 4L80E Torque converter is a triple disc noisy
- TCI 6X in a 68 Chevelle
- 4l80e help required please
- TH350 transmission vs 168T flexplate - clearance issues
- 4l80e smal question help required please
- 4L60 or 700R4
- 8l90e first gen camaro?
- A few 4L80E Questions - Shifters and Compatability Help!
- need help deciding between 6 or 8 speed auto trans.
- th400 to lt4
- 2004R Transmissiln Vendor
- Whats your stall rear gear combo?
- 6l80e rear mount cooler
- 4l85e
- Did I just kill my 200-4R
- Hurst Dual Gate + 4L60E?
- Need a modern automatic for my 69 Firebird
- Transmission temp sensor location- need help
- Help Please....4L70E Behind BB Chevy
- drive shaft yoke options for 6l80
- How do I hookup my 2004R to my Holley ultra street avenger?
- Paddle Shifters ?
- new trans time...what would you do?
- Need shorter Dipstick/tube for my 4L60 transmisison LS swap in Gen 1 Camaro
- Paddle Shifting Opinions
- L92 6l80e
- Cross member for 4L80E in a 67
- 70 Camaro, LSA ... which trans?
- TH-350 Shifter Question - Alignment is "off"
- Ideas...How to Shift a 4L80E
- Full manual 4L80E
- Need Help: 1992 700r4 into a 67 El Camino 400SBC. What do I need to not burn it up?
- Delayed turbo 400 shifting
- 700R4 Hard Shift
- Just put in a 8-speed transmission into my 2nd gen..
- 6l80e Shifter options
- Performance automatic vs. dyanamic racing transmissions for max effort C4?
- Custom Automatic Transmission Shifter Cable Source
- Can someone help me set the kickdown cable on my 700r4? Used a TCI universal cable
- 4L80E vs 6L80E - Are two extra gears worth it?
- B&M super cooler trans cooler
- 6L90E transmission controller help!
- 5th gen camaro shifter on 4L60e
- 4L60e tuning
- Dexron
- paddel shifter 4L80
- 4L80e Shifting
- 6L/8L Programming w/ ZL1-like Performance
- Cooler Hose?
- 6l80 transmission shifting issues
- Twist Machine Paddle Shifter
- TH 350 with lockup
- Transmission Cooler
- Lokar LED Boot Indicator & Sensor kit
- Paddle shifting a 4L80E with a GM computer? Can it be done?
- My 8HP70 swap.
- High stall converter, overdrive low RPM
- Reprogram?
- Low gear driving
- Lt4/10L90
- TCI 6X, no electronic engine braking
- TCI Paddles AND TCI Outlaw w/ bump switches interchangeable use via EZ TCU?
- 69 Camaro TH350 to 4L80E swap - Cam, Converter stall and cruise specs
- 2005 4l65e rebuild help
- 700r4 transmission problems
- hidden costs installing 4L80 transmission in non computer non LS motor
- Transmission filter to pan clearance
- BBC and 4L80E Adapter
- TC lock up
- Transmission Leak
- 4l60e question
- Sport Shifters for 6LXX transmissions
- 8L90 Tap Shifter
- Gen V LT/8l90 tap shift question
- 4l65e shift pressures and steady state pressures
- 4l80 swap dipstick options
- TORQUE Converter Recommendation help
- 4L60 vs 4L80
- C7 transaxle in C5 Corvette
- 1970mustang 351c
- 4l80e Lube problem
- 4L80e front leak issue help…looking for a good shop
- Lokar ESS question
- 700r4
- 4l80e Torque Convertet installed correctly?
- 200R4 or 700R4?
- 400 turbo Gear Vendors OD
- Transmission cooling lines hard/braided
- Shifter recommendations
- 4L65E Only works when cold 200-300'
- 4l80E banjo fittings
- Transmission Swap Question
- 68 Camaro Trans recomendation
- OPINIONS WATED on 700R4 LOCK-UP verses NON LOCK-UP
- Transmission won't shift?
- Converter advice
- How to "unlock" 700R4 convertor without "ported" vacuum??
- solution for mecanical speedo wirh 4L80e
- 700r4 What Transmission Company
- 6l80 Shifter options
- 4L60E Tuning for Autocross and Track Days
- I need a measurement on a Lokar 4L70E/4L60E dipstick
