    Results 1 to 6 of 6
      May 2008
      Chicago
      Transmission Cooler
      Any input on a Trans cooler, the radiator does not have the provision for a cooler. Car is a 80 Trans Am with a 4L60E behind an LS2 with a mild cam and a 10 inch converter. Preferably something with AN fittings
      I like the "stacked" fin type like B&M offers. They have npt fitting so they can be adapted to -6 easily. The one in my C10 is 7.5" x 11.5". Mine is mounted in front of the radiator so if I'm in traffic and the electric fan kicks in it pulls air thru the trans cooler.
      Sep 2016
      Bakersfield, CA
      Stacked plate coolers are the better choice. I personally prefer and use Derale. I'd say a 30K GVW would do it.
      If you want to be even better, choose one with a fan running off a thermal switch and run a thermostat.
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
      1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
      Earl's makes very efficient coolers:
      https://www.holley.com/brands/earls/...e_oil_coolers/
      Feb 2016
      Lawrenceville, IL
      I'll chime in and give another vote for the stacked plate style coolers. Those are the most efficient and effective as long as you can get airflow across them.
      visit us on the web at www.bowlertransmissions.com
      May 2008
      Chicago
      Quote Originally Posted by Craig@Bowler View Post
      Thanks for the input I went with a stacked cooler.
