View Full Version : T56 Magnum & LSX Block
TonyV
02-15-2016, 07:13 PM
ran into a problem when i went to install my tranny....after several attempts we discovered that he input shaft where it starts to taper out into the splines bottoms out on the pilot bearing... the pilot bearing was mounted flush with the crank but does have room to seat further back. it measures about .200" interference, simple fix is to just push the bearing back but its not what we did with the old school chevy stuff so i'm now guessing, anyone have this experience? Or do i need to start researching if I got the wrong input shaft or bell housing?
TheJDMan
02-16-2016, 05:31 PM
In case you missed it, this is the "Automatic Transmissions" section.
sgernon
02-16-2016, 05:36 PM
But to answer your question, there are 2 different pilot bearings. 1 mounts flush to the trans the other is deeper. You need the deeper one. I ran into the same issue.
TANKMASTERJ
07-25-2021, 02:57 PM
Yeah I wanted the flush bearing it's bigger.
And I wanted to run the LS9 clutch. And a Tilton TOB. I lacked .500 for the fit and another .125 for the air gap on the Tilton.
So I machined a .625 steel spacer between the trans and bell housing. Quick time
It fits nice. It's. On my build thread if you need a look see
Jason's 67 pro touring camaro build
Jason
csouth
07-25-2021, 06:13 PM
Jason
The last update to this thread was 5yrs ago....
