View Full Version : Th400 to 2004r question
keith4909
10-29-2016, 07:01 PM
Got the tranny in but forgot to swap the speedo housing. First question, will my th400 speedo fit in my 2004r? If it doesn't, where can I get a plug to just delete the outlet? The diameter of the hole on the tranny is at least 1.5". Thank you
Craig@Bowler
10-31-2016, 07:30 AM
The TH400 will not fit. We have the replacement speedo adapters if you end up needing one, otherwise at one time cobra transmission had a plug you could buy. May be worth checking into.
keith4909
10-31-2016, 03:44 PM
I measured the hole and since I won't run a speedo cable I just picked up a Dorman 02600 expandable freeze plug so the oil won't spill out.
