View Full Version : Gen 1 Camaro Planning
HerbyJr
06-18-2016, 08:30 AM
I'm planning out the power train in my 1967 Camaro and thought I'd ask for some thoughts on automatic transmissions. I haven't yet chosen the engine so I'm pretty wide open, but I know I'll be running a modern LS type engine. I want to go with an engine transmission combination that doesn't require a lot of mods to the tunnel if possible. My goal for the car is a pro-touring vehicle that I can auto-cross on occasion. I'm running the stock front sub-frame with Global West upper and lower control arms, along with QA1 shocks. The rear has a full TCI Torque Arm suspension running Ride Tech adjustable coil overs. She's been mini tubbed and a has a Currie built 9" rear end holding 3.89 gears. My goal is to have something with a lot of torque, but still able to run 75-80 on the highway without feeling like I'm about to redline.
Is someone here familiar enough with Gen 1 Camaros to tell me if one of the modern 5 or 6 speed transmissions with overdrive will require tunnel mods to fit into my 67? Minor mods, may be fine, but I'm not looking to rebuild the floor/tunnel.
Any thoughts on what would be a good fit for my goals and the vehicle would be greatly appreciated.
HerbyJr
06-21-2016, 01:52 PM
Kinda quiet around here. Any thoughts?
ilikeike
06-21-2016, 02:01 PM
Not sure about the LS,but the TKO 5 spd fits with my SBC (68 Camaro) and about a 3 degree down angle and no tunnel mods.
I haven't seen a build with the 6 speed not requiring tunel mods yet.
HerbyJr
06-21-2016, 02:06 PM
Thanks Ike!
Craig@Bowler
06-24-2016, 12:01 PM
If you're wanting to go automatic you can use either the 4L60 or 4L80 series transmissions in your Camaro without much if any modifications. Depending on how much horsepower/torque your engine is making either will be a great choice. We build several configurations of each model to fit different situations. If you're interested in getting some pricing give me a call 618-943-4856 or send me a message and I'll be happy to help you out.
