    Results 1 to 3 of 3
      Holmes Hollow, Ontario Canada
      10 camaro shifter for a 4l65?
      Can anyone tell me if the shifter for a 2010 camaro could control a 4l65?
      Scott
      ____________________________________________
      Scott
      Apr 2012
      Woodstock, IL
      The shifter itself is mechanical so yes it will actuate a cable like what is on the 4L- but the camaro has a Manual mode for use with the paddle shifter that will not be able to be used. So your 1-2 gears will not be used, third gear will be "M" and 4th will be D.
      -Dale
      SchwartzPerformance
      Thanks. It works but only kind of. What I wanted was to use a hurst hard drive shifter. I wonder if there's another shifter the hard drive will work with.
      Scott
