View Full Version : Disc Brakes
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Looking for some help with my recent brake problem (4 replies)
  2. Soft pedal during turns (2 replies)
  3. Ideas?....4 wheel discs.....good brake performance but it takes too much pressure.... (10 replies)
  4. Can I use 05 gto rear calipers on my 81 Camaro? (2 replies)
  5. Plumbing Hydroboost with March 9600 Pump and PSC Remote Reservoir (0 replies)
  6. 69 camaro w/ c5 brakes hard pedal, can not find problem. (0 replies)
  7. AJs1Luv Brake Issues! (10 replies)
  8. Im in a pickle with Breaks..advise (2 replies)
  9. 68 Nova brake upgrade questions. (4 replies)
  10. Willwood brake and clutch pedal (8 replies)
  11. 4th Gen Disc on 1st Gen Firebird CNC Cutting my own brackets (7 replies)
  12. Brake Pedal not returning all the way. (1 replies)
  13. Anyone With Baer SS4 rear disc? (2 replies)
  14. Will LS1 rears fit full size Chevy rear? (7 replies)
  15. Question About "Bench" Bleeding Master Cylinder (3 replies)
  16. Camaro 67 - 4 piston vs. C6 or Z06 corvette calipers? (3 replies)
  17. New Master Cylinder Leaking at the boster? (3 replies)
  18. what master cylinder with Kore3 brakes (6 replies)
  19. Vendor for C6 calipers (1 replies)
  20. 69 Camaro / LS1 brakes, will Classic tube stainless kit work? (hard lines) (0 replies)
  21. Discs with 15s (11 replies)
  22. Mustang 8.8 rear with Z06 brakes (16 replies)
  23. '67 Firebird Disc Brake conversion using OEM parts. (1 replies)
  24. 1967 camaro which hydraboost to go with? (10 replies)
  25. c6 zo6 front calipers for sale (2 replies)
  26. Master/Booster Advise! (1 replies)
  27. Moser DBP floater rearend (8 replies)
  28. Proportioning Valve question? (19 replies)
  29. C5/C6 or other big brakes behind the17" Year One Rally wheels? (2 replies)
  30. no rear brakes c5 swap gm a body (1 replies)
  31. A few brake questions. (1 replies)
  32. LS1 Brakes locking up at full pedal depress? (5 replies)
  33. 68 Camaro ccp brakes or who? (5 replies)
  34. C5 master with hydroboost? (24 replies)
  35. Unusual brake pedal problem (13 replies)
  36. hopefully someone can share some advice (3 replies)
  37. Rear Disc Calipers wiggly room? (3 replies)
  38. Need to upgrade brakes (21 replies)
  39. 2lb Residual Vavles (1 replies)
  40. 2014 C7 Corvette Brakes - Any Info on Part Numbers and Availability? (29 replies)
  41. Rear Brakes 88-92 Fbody 1LE vs 93-97 Fbody (3 replies)
  42. new 4 wheel disc swap and rears are doing most of the work (14 replies)
  43. Power Brake issue. Hard pedel to soft! (0 replies)
  44. Measuring stopping performance (2 replies)
  45. 74 El Camino front disc brake assembly on 70 Chevelle??? (3 replies)
  46. disc (7 replies)
  47. Caliper hose length C5/LS1 brakes? (7 replies)
  48. Baer 6P calipers (2 replies)
  49. Opinions on Master/Booster combo (18 replies)
  50. Is this a problem.... (5 replies)
  51. Bleeding brakes with a motorcycle bleeder? (4 replies)
  52. 300mm front rotors - Caliper Options (0 replies)
  53. Master cyl questions (4 replies)
  54. Ford 9" and LS1 brakes - I messed up (16 replies)
  55. Corvette Z06 6 piston caliper adjustment (5 replies)
  56. Proportioning valve question (5 replies)
  57. C5 brake Abutment brackets and questions... (1 replies)
  58. Airmaster Brakes air assist braking (6 replies)
  59. Rear disc with parking brake for 15 inch wheels (5 replies)
  60. Need to stop....... Kore3 maybe? (14 replies)
  61. Kore3 or Wilwood Challenge series? (6 replies)
  62. C5/C6 ABS sensor (22 replies)
  63. 12.19 inch rotors for wilwood calipers on A-body? (9 replies)
  64. Front-rear line pressure bias (2 replies)
  65. CPP C5 Spindle Brake Kit - Who Has Used Them? (31 replies)
  66. Rear discs are locking up after a short drive (4 replies)
  67. Corvette rotors on A-bodies? (3 replies)
  68. C5 caliper identification (3 replies)
  69. Wilwood 14" Brakes (7 replies)
  70. My C5 front brakes does not work (17 replies)
  71. C5 brake question (0 replies)
  72. Hydraboost and Power steering issues (5 replies)
  73. Narrowed 9" Currie rearend now brake caliper hits springs (17 replies)
  74. Bleeding wilwood's (16 replies)
  75. 69 Camaro brake kit suggestions (3 replies)
  76. C6Z06 brakes (33 replies)
  77. LS1 disc brake swap parts (8 replies)
  78. How can I use C5,C6 brakes with RideTech Tru Turn? (6 replies)
  79. Bell crank/short hydroboost setup? (0 replies)
  80. D52 pad coeff. (43 replies)
  81. help 1st gen wilwood manual master cylinder pedal help (1 replies)
  82. Same size brake calipers front and back (4 replies)
  83. Brake swap, soft pedal need ideas. (24 replies)
  84. What Wilwood Brakes for 18" Wheels (1 replies)
  85. CTS-V calipers/rotors brackets (3 replies)
  86. Proportioning valve Question (4 replies)
  87. how to tell what size bore your M/C is? (4 replies)
  88. How does manual master cylinder mount to firewall? (5 replies)
  89. Disc Brake conversions that fit under 15" wheels? (14 replies)
  90. D52 brake Pad Chart (1 replies)
  91. Real simple disc upgrade question (4 replies)
  92. Breaks dont fit (6 replies)
  93. What size bore master cylinder for C5 front/98-04 F body rear calipers/rotors? (4 replies)
  94. Willwood 19 days still no brakes shipped! (19 replies)
  95. Thread sealer for bleeder screw (4 replies)
  96. Willwood Challenge Series (1 replies)
  97. Brake combo question (3 replies)
  98. What Is This Parking Brake Cable Part Called? (14 replies)
  99. when are your brakes to big ? (38 replies)
  100. Do I need a new Master Cylinder? (2 replies)
  101. Effects of 7/8" master with boster? (3 replies)
  102. Silicone fluid swaps (1 replies)
  103. Needing a pad change on manual brake setup (1 replies)
  104. dynalite 4 piston brake pads (7 replies)
  105. Do the Wilwood D52 replacement calipers work any better than stock D52's? (35 replies)
  106. PBR 6-piston plain silver calipers source? (12 replies)
  107. Whats more important? Rotor Diam or Piston area? (25 replies)
  108. rotor redrill help needed (16 replies)
  109. no clearance. rotor and abutment. (17 replies)
  110. SSBC rotor hat help. (4 replies)
  111. Why do you like hydroboost. (1 replies)
  112. Need help deciding what brake booster n mastercylinder to match with baer ss4+ brakes (2 replies)
  113. Help deciding between 2 brake setups (1 replies)
  114. c5 disc and 17" torq thrust rims..will it work? (8 replies)
  115. Which brake line set to use? (15 replies)
  116. First gen Camaro brake line routing diagram or photos (4 replies)
  117. C5 ls accessory drive with DSE steering rack and Hydratech hydroboost (0 replies)
  118. Wheel upgrade stock disc brakes (6 replies)
  119. Corvette Parts for Second Gen Camaro (1 replies)
  120. 14in wilwood (3 replies)
  121. line flaring (5 replies)
  122. What to adapt,the master,the lines,the prop valve? c5 master/booster swap (0 replies)
  123. 2nd Gen brake booster with factory disc/drums. need help (6 replies)
  124. Second gen camaro brakes will not bleed (10 replies)
  125. Muscle Car Brakes (MCB) Drum brake upgrade. (6 replies)
  126. master cylinder question (0 replies)
  127. brake booster dilemma... (10 replies)
  128. Wanting to add disc brakes to my '71 Dodge D-100. Any suggestions? (0 replies)
  129. Vacuum Booster Question (5 replies)
  130. Black coating on Wilwood brakes, do you have to strip it off? (5 replies)
  131. Rear Brake configuration using LS1 setup, and a Ford 9 (10 replies)
  132. Please help me confirm master cylinder choice (2 replies)
  133. Booster choices,sawaping everything on my 69 to c5 ,looking for best options (0 replies)
  134. Need help slecting Disc Brakes.... (4 replies)
  135. Speedway Motors 13" brake kit for Camaro (7 replies)
  136. Is anyone still using C4 brakes? Second gen Camaro questions (6 replies)
  137. Any advice on 71 Camaro disc brake conversion (5 replies)
  138. Picked up some new brake line. Anyone else use this? (24 replies)
  139. fitting compatability- Kore3 flex lines (3 replies)
  140. Dead space!! (16 replies)
  141. upgrading my disc brakes to c5 brakes got questions. (2 replies)
  142. G Body LS1 brake upgrade (10 replies)
  143. C5 corvette brakes/ Slotted or not? (8 replies)
  144. LS1 Rear upgrade kit. (3 replies)
  145. 1969 Camaro - Where and What disc brakes to buy?? (12 replies)
  146. Need some help/advise on my Manual brake setup (15 replies)
  147. Q: AstroVan HydroBoost Upgrade? (5 replies)
  148. Adjustable Proportioning Valve location (7 replies)
  149. 1968 firebird booster/master advice needed (3 replies)
  150. Wilwood mc brake line routing 69 camaro (1 replies)
  151. 65 GTO Master Cylinder (0 replies)
  152. 1st Gen C5 Caliper Adapter Bracket -- Template (7 replies)
  153. Master Cylinder Questions (3 replies)
  154. Math for determining needed brake size (9 replies)
  155. Rusty Wheel Cylinder Pins (3 replies)
  156. Trying to find the right brake package. (16 replies)
  157. Any pics of custom brake line layouts from master cylinder, line lock, prop valve? (6 replies)
  158. Axles for rear discs-Duthcman (3 replies)
  159. Issue... Welding on aluminum adapter brackets (7 replies)
  160. Custom rotor hats? (4 replies)
  161. help need some info (0 replies)
  162. Drilling Rotor Hat for Larger Studs (21 replies)
  163. Wheel sizes? 13" 6 piston front, 12" 4 piston rear. (6 replies)
  164. 2nd gen f body z28 rear brake hose (8 replies)
  165. Titanium rotors experience (2 replies)
  166. PBR/Baer E brake ?? (4 replies)
  167. Recoating Calipers? (6 replies)
  168. Can I run Stock booster and master with c6 z06 (2 replies)
  169. Stock caliper vs. TRSD Signature Series (1 replies)
  170. C5 master with manual brakes? (7 replies)
  171. Baer claw track system? (2 replies)
  172. Here's Your Rear Disk Brake Lesson for the Day (6 replies)
  173. Trouble getting good pedal (14 replies)
  174. anyone explain true diff on Willwoods W6A and Narrow Superlite series brake calipers (4 replies)
  175. Older Baer track setup,VS 6 piston setup. How much better? (1 replies)
  176. Discoloration on Brake Rotor. What is it? (2 replies)
  177. need some feedback from guys running proper manual brake systems (21 replies)
  178. Banjo fittings on master cylinder (15 replies)
  179. Bad Ast hydro-boost line routing (8 replies)
  180. LS1 Calipers - Where did you buy your? (12 replies)
  181. braided line size (2 replies)
  182. 72 cutlass rear disc brake question (3 replies)
  183. budget rear disc brakes?? (51 replies)
  184. what is a good price on ls1 brake stuff (5 replies)
  185. Let me run this by you guys..... (11 replies)
  186. Being different (Mitsubishi Evolution Brembos on 1g Firebird) (8 replies)
  187. Hydraboost vs Electric assisted brakes pros/cons Which is better? (18 replies)
  188. Brake Issues (2 replies)
  189. Safety Wire Question -- Dorman 10160 "Utility/Mechanic's Wire" (9 replies)
  190. 2010 Z06 c6 brakes into 1962 impala (9 replies)
  191. Rotors and calipers (9 replies)
  192. Using two different types of brake calipers ? (4 replies)
  193. swapped brake booster, no brakes now (13 replies)
  194. 4 Wheel Disc Brake Setup for 68 Olds 442 (2 replies)
  195. Need a narrow rear caliper (0 replies)
  196. Need recommendation for rear calipers (using 6 piston C6 fronts) (3 replies)
  197. caliper clearance (2 replies)
  198. Wilwood rear discs - hardlines and e-brake cable (11 replies)
  199. 12" or 13" rears? (4 replies)
  200. Front Disc Flex Line Design/Routing (4 replies)
  201. Red Loctite 271 Scares Me (21 replies)
  202. What booster should I buy? (6 replies)
  203. Ls1 rear brake problem (2 replies)
  204. C6 Z06 rear brakes, do they require 19 inch wheels (12 replies)
  205. what power booster for my car to make it power brakes? (0 replies)
  206. What year corvette master cylinder for manual brakes? (5 replies)
  207. HELP!! after a short ride, my LS1 front brakes stay locked up!!! (12 replies)
  208. Master cylinder push rod problem (2 replies)
  209. Brake Lines Art morrison chassis (9 replies)
  210. 2012 regal gs front and rears brakes ...anyone? (7 replies)
  211. C6 Z06 rear brakes... ford Nine Inch (8 replies)
  212. What parking brake cable kit to use with Wilwood rear disc brakes (15 replies)
  213. Booster/Master?? for C5 front/ LS1 rear on 1970 Chevelle (7 replies)
  214. SRT8 or Z06 route? (3 replies)
  215. Bolt spacing on rear C5/C6 caliper? (0 replies)
  216. 71 cutlass and Baer brakes (3 replies)
  217. bleeding the hydoboost (1 replies)
  218. Baer Disc brake on rear Problem (0 replies)
  219. C4/C5 Brake Adaptors (12 replies)
  220. Big truck brakes (0 replies)
  221. Brake advice wanted: c5/6 spindles/ 9" rear (4 replies)
  222. 1st gen Camaro Firebird C5 disc brake parking brake soloution (0 replies)
  223. New Booster Necessary? (1 replies)
  224. Need a Stop Tech dealer! (1 replies)
  225. Brake bias problem - help needed (5 replies)
  226. Junkyard disc brake setup for a s10 (7 replies)
  227. Searchig - B Body spindles for F Body brake upgrade (5 replies)
  228. Brake line size? (6 replies)
  229. 2 cars 2 brake problems. camaro 2 hard 55 to soft (6 replies)
  230. master cylinder sizing. (14 replies)
  231. Stock D52 caliper with manual brakes? (13 replies)
  232. Wilwood Brake Problems! (17 replies)
  233. Wilwood Caliper Alignment (44 replies)
  234. Wilwood 14" rotor vs 13" rotor with Wilwood SL6R (3 replies)
  235. How do you know if your prop valve is set correctly? (7 replies)
  236. scary situation today (8 replies)
  237. Brake lines need pointers (23 replies)
  238. how about C3 Corvette brakes on a 3rd gen Camaro? (2 replies)
  239. poor pedal after pad swap? (7 replies)
  240. Need front drum hubs for a 67 chevelle , compatibility ? (6 replies)
  241. Brake Decision- Wilwood-Baer-CPP? (14 replies)
  242. Who has Ls1 caliper swap brackets? (2 replies)
  243. Brake line routing vs. trapped air (4 replies)
  244. Bolt-on A/G Body rear disks with c-clip eliminators (8 replies)
  245. LS-1 break conversion (3 replies)
  246. Wilwood disc size question (8 replies)
  247. ls1 vs c5 vs c4/c5 hybird for street (20 replies)
  248. Moving pads causing a click? (3 replies)
  249. Blazer anti-lock brakes for my vega (2 replies)
  250. GMR - Brake Man Components (18 replies)
