View Full Version : Any advice on 71 Camaro disc brake conversion
Gasman303
02-04-2013, 06:37 AM
I'm running 275-35-20 in the rear of my Camaro, I want to convert the rear drum brakes to disc. I like the cpp big brake kit but they make only 1 st gen Camaro setup. My car has the 8.5 10 bolt rear end. I'm also looking into wilwood or Kore3 kit. I'm looking for appearance a than performance, because of the space I need to fill running the big 20's out back. Any suggestion would be appreciated
jpgolf14
02-04-2013, 08:05 AM
Take a look at the 5th gen Camaro SS / CTS-V rear brakes. They are huge and very affordable. If you are going for looks, these will be hard to beat for the money. 14.5" rotors and 4 piston Brembos. You will need to make an adapter bracket for the differential. I can help with that if you go with those. These are in 19's. Are you planning to run an e-brake?
https://static1.pt-content.com/images/pt/2013/02/6932666616_2ebdebf1a6_h-1.jpg
Gasman303
02-04-2013, 06:17 PM
I'm considering running a E-brake being that I'm installing a tko600 5 speed trans?!! Who sells this setup? it's what I'm looking for
jpgolf14
02-05-2013, 09:34 AM
Running an e-brake does complicate things. The setup pictured does have an e-brake though. The only thing that needs to be figured out is the e-brake cable attachment and routing.
I have toyed around with selling this bracket, but the bracket would need to be slightly redesigned for the shorter axle offset of the 10 bolt vs my dana 44.
https://static1.pt-content.com/images/pt/2013/02/7237531342_d8a2c515e6_h-1.jpg
The redesign would probably be a two piece design to lower the cost. The inner piece would be steel and the outer aluminum.
https://static1.pt-content.com/images/pt/2013/02/7583682980_effddbc048_b-1.jpg
John
Gasman303
02-05-2013, 07:16 PM
That's trick!! I'm dreading to tackle the ebrake set up
Classic Nova & Performance
02-07-2013, 08:16 AM
There are several brake kits for your application that come with e-brakes. They are a pretty straight forward install and work well. I personally wouldn't do a street car w/o an emergency brake.
