View Full Version : disc
hag6888
05-18-2013, 02:28 AM
What are the best priced and performance brakes for the 67-72 Chevy trucks not wanting to convert my lug pattern
Ron Sutton
05-18-2013, 09:08 AM
What is your lug pattern ... 5x5?
Do you have discs or drums now?
Do you want to lower the truck or leave it the same height?
john31s
05-18-2013, 07:13 PM
Pretty sure they were six lugs stock..
Have you considered these:
http://www.classicperform.com/NewProducts/2006/NewFiles/BigBrakeKit.htm
Convert to modern big disk brakes and switch over to 5 lugs at the same time.
Ron Sutton
05-24-2013, 10:42 AM
hag6888 ?
Apogee
05-25-2013, 03:15 PM
The front drum brake applications were 6-lug, disc became an option in '72 IIRC and were 5x5. Best priced options would arguably be the OE front disc brakes with 11.85" x 1.28" rotors, D52 calipers, etc. Best performance would be something bigger, newer, etc. Best value depends on what you intend to do with your truck since too much brake means spending money that could have otherwise been spent elsewhere, however too little brake and you'll be doing it twice.
Answer the questions above and include your intended use and you should get better, more specific and more detailed information from the masses.
Tobin
KORE3
hag6888
06-02-2013, 07:29 PM
There 6bolt 5.5 bolt spacing
hag6888
06-02-2013, 07:31 PM
And yes I have drums now
Randy67
06-03-2013, 05:38 PM
The 2000s Silverado 1500 have rotors with 6x5.5 rotors that slip over hubs (maybe your drum hubs will work). Could be a starting point for a low cost setup, maybe Tobin have some ideas on this.
I also found this: http://www.bobschevytrucks.com/1963-1970-truck-stock-spindle-disc-brake-kit-6-lug.html Not sure how performance it would be, but an improvement over drums.
