View Full Version : 14in wilwood
Jenkins
02-20-2013, 02:26 PM
Has anyone ran a 2in drop spindle with w6a wilwood on a 1969 camaro or nova any help would be great talked to wilwood today and there not for sure
Apogee
02-22-2013, 11:46 AM
Shouldn't be a problem so long as the drop spindle in question is compatible with the OE brakes that the Wilwood kit is designed for. I assume you're referring to their 140-10920 (http://www.wilwood.com/BrakeKits/BrakeKitsProdFront.aspx?itemno=140-10920&year=1969&make=Chevrolet&model=Camaro&option=Disc+Brake+Spindle) W6A kit? I remember there may have been an inner oil seal issue with one of the Wilwood hubs, but I can't seem to find that thread...maybe someone else will chime in.
Tobin
KORE3
Jenkins
02-23-2013, 03:19 AM
Yes that kit is it I've got a lot of run around but your right if it is oem it should work just look to see if anyone has run a set up like that before I got them and they didn't work thanks
mario65
02-26-2013, 09:29 PM
I was running a ridetech 2" drop spindle with stock discs on my 67 firebird. I went to a wilwood 13" rotor and 6 piston caliper. It bolts in the same locations and the wilwood recommendations for spacers and shims was exactly the best fit for my car.
