benno505
07-28-2013, 01:21 PM
in my 68 charger i have Wilwood:
* dual tandem master cylinder
* 4 port prop valve
* 12" drilled and slotted discs
* 4 piston calipers
* all brand new stainless brake lines and stainless flex lines.
Car has been driving perfectly for a few weeks, then yesterday driving down the highway and the brakes locked on, the brake pedal was hard as a rock and would not budge
managed to unwedge them and get the car home.
pulled master cylinder and brake booster off tested both and they both working fine, put booster back on and checked pedal movement, all good
put master cylinder in vice and ran the return hoses and bench bled the MC, it worked fine.
put MC back onto booster and reconnected the brake lines up and brake pedal is still hard as a rock.
Any ideas?
* 4 port prop valve
* 4 piston calipers
Any ideas?
