View Full Version : Need recommendation for rear calipers (using 6 piston C6 fronts)
XLexusTech
11-09-2012, 12:34 PM
My builder recommends a floating caliper setup for the rear. I had planned on using the C6 Big Brake kit front and rear but that's out now.
jpgolf14
11-09-2012, 06:03 PM
It really doesn't matter a whole lot as almost anything will be sufficient for the rear. Good options include the C5/C6 rear or the C6 Z51 if you want a larger rotor. Or Baer has an option for a 14" rotor with the C5/C6 calipers.
What are you using for a prop valve?
XLexusTech
11-09-2012, 06:10 PM
worried about runout and pad pushback with the nine inch.... No propp valve yet so i can use whichever i like.
Motorcitydak
11-09-2012, 06:53 PM
I was just thinking about the exact same thing for my car. I have the zo6 front calipers and rotors. I have a full floater rear tho and was planning to get the biggest bolt on rotor rings I can find. Could use a hand picking calipers tho. 4 piston's but input on piston size would be cool. Im using a Tilton pedal assembly and triple master cyl's
