carguykeith
08-27-2012, 08:47 AM
I just added this to my build thread, but thought I might as well make a thread here in case someone was searching.
I had some issues with a weld-on setup I had originally installed when I couldn't find a bolt-on setup so did some internet searching to come up with another solution. What I found was that almost all bolt-on kits attached from the outer face of the axle flange, the same as c-clip eliminators do. THis causes a problem with the rotor offset not lining up with the caliper due to the added thickness of the eliminators vs. drum brake backing plate.
So what you need is a caliper bracket that bolts on from the rear of the out axle flange, which I finally found. I'm not affiliated with Speedway just a customer and woudl be happy to edit this thread if there are other manufactures of a similiar kit.
Anyways here is the kit:
http://www.speedwaymotors.com/GM-10-and-12-Bolt-Bolt-On-Rear-Disc-Brake-Kit,14015.html (http://<a href="http://www.speedwaymotors.com/GM-10-and-12-Bolt-Bolt-On-Rear-Disc-Brake-Kit,14015.html" target="_blank">http://www.speedwaymotors.com/GM-10-and-12-Bolt-Bolt-On-Rear-Disc-Brake-Kit,14015.html</a>) Oh yeah, I did change to these: http://www.speedwaymotors.com/Wilwood-GM-Iron-Metric-Caliper-2-Inch-Piston,24242.html (http://<a href="http://www.speedwaymotors.com/Wilwood-GM-Iron-Metric-Caliper-2-Inch-Piston,24242.html" target="_blank">http://www.speedwaymotors.com/Wilwood-GM-Iron-Metric-Caliper-2-Inch-Piston,24242.html</a>) Wilwood 2” piston calipers instead of the stock metrics to help balance out the C5 fronts a little better.
Here it is all bolted up:
Of course in my case “bolt-on” still required a plasma cutter, welder, and a 2lb hammer but I’m still pretty happy with the kit overall. Really to be fair the only reason it took all of the extra work is how Strange Engineering builds their c-clip eliminators/ They require the 4-bolts be threaded in from the rear instead of from the front face and the added length of the bolts were just enough that the shock/ lower control arm mounts interfered.
