View Full Version : 2014 C7 Corvette Brakes - Any Info on Part Numbers and Availability?
BrianP
05-20-2013, 02:50 PM
Hi,
Does anyone have part numbers and availability of the 2014 C7 Corvette Brakes?
I think these would be perfect for my Tyler / TiTo / Blake / SpeedTech / AFX Spindles.
Specs:
4 Piston Brembos.
12.6" Rotors
76359
Build-It-Break-It
05-30-2013, 05:42 AM
Have you tried calling a local Chevy dealer?
andrewb70
05-30-2013, 06:07 AM
Does the C7 spindle have the same brake mounting dimensions as the c5/6 spindle?
hifi875
05-30-2013, 06:08 AM
Just saw a yellow 2014 yesterday. They are out testing them a lot here where I live. needless to say, it looked bad ass. At first I caught it out of the corner of my eye. thought it was a Ferrari 458 from the back side. Cant wait to drive one.
2wolf_Michael
05-30-2013, 02:33 PM
I know there are a few places on the corvette forums that are selling the Carbon rotor as a kit for C6 corvettes. Will see if I can find a link. Not sure about the calipers though.
Simmo
05-31-2013, 12:28 AM
There was some hi-hes photo's somewhere on the net but all I can find is this;-
http://www.brembo.com/en/News/Pages/Brembo-chosen-for-2014-Chevrolet-Corvette.aspx
Brembo now makes the whole assembly so I'm real interested in what's changed from the C6...I'm wondering how long it'll be before my not even built frame will be obsolete!
Whistler
05-31-2013, 03:55 PM
Every single part of the C7 chassis is new. While I'm sure the bolt pattern on the studs is the same so the rotor will slip on, I'd be very surprised if the rest didn't require modification to get to work.
andrewb70
05-31-2013, 05:47 PM
I remember seeing C6 ZO6s running around BG before they were out. This was when I lived in BG. Miss that town.
SLO_Z28
06-08-2013, 08:33 PM
I cant think of their name right now but its a French company that makes those brakes. I was doing some work on a car that had them on it a long time ago, and we couldnt get any parts from the manufacturer. We ended up going with some Hurst brakes that worked better anyways.
BrianP
01-10-2014, 12:12 PM
ROTORS:
20981819 Front brake rotor; 2 per vehicle. (JL9 brake system) Sold individually
20981820 Rear brake rotor; 2 per vehicle. (JL9 brake system) Sold individually
Or
20981821 Front brake rotor; 2 per vehicle. (J55 brake system) Sold individually
20981822 Rear brake rotor; 2 per vehicle. (J55 brake system) Sold individually
CALIPERS:
22847785 Driver side front brake caliper; (JL9 brake system) Red in color
22847790 Passenger side front brake caliper; (JL9 brake system) Red in color
22847809 Driver side rear brake caliper; (JL9 brake system) Red in color
22847814 Passenger side rear brake caliper; (JL9 brake system) Red in color
OR
22847795 Driver side front brake caliper; (J55 brake system) Red in color
22847800 Passenger side front brake caliper; (J55 brake system) Red in color
22847809 Driver side rear brake caliper; (J55 brake system) Red in color
22847815 Passenger side rear brake caliper; (J55 brake system) Red in color
Now I just need to know if the caliper mounts are the same as the C5 and C6.
Buryingthesun
01-10-2014, 01:33 PM
buy one then return it ;)
srh3trinity
01-10-2014, 07:56 PM
I might know where a set are along with an lt1. One of my employees had just bought a c7 and was on the interstate, slowed for a wreck and a 4x4 truck hit her from behind and actually wound up on top of the c7.
joshuaweber
02-01-2014, 03:48 PM
let me know exactly what dimensions you need I'll see if I can pull em.89512
Chevelle598bb
02-01-2014, 07:00 PM
What car (spindle) do you have those on?
joshuaweber
02-01-2014, 10:26 PM
89534
68 camaro. It is the oe drum spindle, with the top boss milled to the same plane as the lower boss with laser cut brackets. The oe hub is turned to rotor id.
I have the measurements at work so if you need specifics let me know. I believe caliper bolt spread is 5.039". Rear are ls camaro. The booster and master are ls camaro but soon to be manual again.
joshuaweber
02-01-2014, 10:28 PM
Here are the pn that I used89535
Chevelle598bb
02-02-2014, 06:14 AM
89534
Did you use a c5/c6 conversion brake bracket such as kore3 or did you make your own? Where did you buy your calipers and rotors.
joshuaweber
02-02-2014, 10:16 AM
The are of my own design. They are laser cut from .3125, designed around the 13.6" rotor. The downside is the need for a min 18" wheel. I did not try but you could try to move the caliper mount holes to make them fit the 12.6-inch (320 mm) front rotor.
The parts were acquired via City Chevrolet in San Diego, ask for Rob L. I used a vin I found online, my problem is that I bought the parts in October 2013, so they were hard to get but it should be easier now.
I want to thank everyone on this site! I usually dont post my projects. Their are some really smart people on this site (and vendors like Kore) without their knowledge and willingness to share on silimar projects I would have not been able to research what I needed to apply to this.
Chevelle598bb
02-02-2014, 11:36 AM
After looking at the c7 spindle and the c5/c6 spindle I dont think the brake mounting loints are the same. They appear to be in different locations. The c7 spindles caliper mounting points are closer to the hub than the c5/c6 spindle. That being said they would not be a bolt on deal with conversion brackets for brake swaps.
Nice work joshuaweber on making a set of brackets to work on the old a/f/x spindle. the set up looks nice.
andrewb70
02-02-2014, 01:47 PM
You should post more and share your ideas. Clearly, you have some good ones. I would love to see how you mounted the caliper and the bracket.
joshuaweber
02-02-2014, 09:03 PM
89597 per the request here is a photo of the bracket. I did this on the cheap, so don't make fun of the UCA and LCA. Some day I'll do a sub frame and ls motor but this is the current state.
joshuaweber
02-02-2014, 10:11 PM
kustom71
02-03-2014, 11:32 AM
I think its awesome!
Great work
I was just asking a question somewhat on the order of this
I wanted to mount new camaro or cts 4piston calipers on a 71 chevelle with a drum spindle.
My question was more along the lines of is there a great enough difference in braking between this setup and a 2 piston c5/c6 setup to justify the cost?
Going from manual drums to any of these setups is sure going to be a major difference so value was my question.
Yuo made it work it looks really good
Good luck with the rest
BrianP
02-03-2014, 11:50 AM
Could you please measure how far out the caliper sticks out past the rotor wheel mounting surface?
joshuaweber
02-03-2014, 04:41 PM
Kustom71:
I did not have the c5/c6 setup I too had manual drums so any system is an improvement. But if you believe the marketing department version; "Behind those wheels are standard Brembo brakes that, while slightly smaller in diameter than before, boast 35 percent more swept area thanks to larger pads that cover more area on the rotor face. Z51 cars get larger front discs (13.6 inches versus 12.6 on the base C7) with 6 percent more swept area than a current Corvette Grand Sport and a lot more bite. Chevrolet says the new Stingray will stop 11 feet shorter than before, putting its 60-0-mph braking comparable with that of the mighty ZR1, which we measured at 94 feet."
Read more: http://www.motortrend.com/roadtests/coupes/1301_2014_chevrolet_corvette_stingray_first_look/#ixzz2sJCsPp00
I believe without ABS, traction control and those huge tires this is all subject. I dont remember but I think the gm bill was +/- $1500 not bad for oe parts, imo.
BrianP:
wheel mounting surface to out sided face of caliper 1.4331"
Hat to face of rotor: .8268
Overall od of the calipers on 13.6 rotor: 16.1545" (if you remove the pad weights you could pick up a little room)
Rotor id @ hub:2.782" (hub od 2.78 from a 2.76 lead in)
All dimensions should be verified...
I looked at the 2010 camaro brembo and newer ctsv drawings and this seemed to be the best direction for me to go in.
andrewb70
02-03-2014, 04:45 PM
While it is nice to have larger pads for better heat dissipation and longer pad life, it does not effect brake torque.
Does anyone know the piston area of these new calipers?
joshuaweber
02-03-2014, 05:27 PM
4 piston, 42mm dia. fixed mount front caliper (2014 Brembo J55 Z51)
[rad. = .827" so, 2.148626 area of each piston x2 (due to fixed caliper)= 4.297252]
http://www.essexpartsblog.com/news/c7-stingray-brake-analysis-are-they-track-worthy
silver69camaro
02-14-2014, 07:35 AM
Unfortunately they are very different.
Pete68
08-31-2014, 12:45 PM
Those C7 brakes are so pretty.
C5 is a great swap, C6 even better. The front rotors on the C7 must be 14" or 15" right?
70ptta
05-25-2017, 12:23 PM
does anyone make a bracket to use c7 z06 brakes with ats or ridetech spindles?
