View Full Version : New Master Cylinder Leaking at the boster?
daveybtv
06-30-2013, 11:01 AM
Is it bad or did I do something wrong?
Apogee
07-03-2013, 08:57 AM
Brand new installation or is this a used unit that's been in service for a while? Generally speaking, if/when they leak fluid from the piston end, it's time to rebuild or replace the unit. That said, I've also seen new and used units weep a small amount of fluid during bleeding that ended up bench bleeding fine and then running for years, so a little more info might be helpful.
Tobin
KORE3
daveybtv
07-03-2013, 01:52 PM
IT was a new one, Cheep from Advanced auto I did not bench bleed it So I went and got another one. This time I bench bleed it just put it on so far so good. Now I have to re-bleed the system and hopefully this will fix it.
woody80z28
07-31-2013, 06:30 AM
I just had this happen with a brand new ACDelco master in my Beretta. Didnt notice anything when I bench bled it, but it was leaking out the booster. I replaced the master and all is fine except now when I'm on the brakes I can hear a vacuum leak and the idle pick up. So keep an eye on it and make sure your booster didn't get wrecked by the leaky master. I gotta grab a new booster to put in it.
