sjaroslo
10-29-2012, 04:43 PM
So, having finally gotten the front discs and calipers mounted, I'm moving on to the hydraulic connections. I have an Art Morrison front sub-frame and Wilwood discs. I'm using the Morrison thru-frame fittings (http://artmorrison.com/layout.php?y=store/&x=new) and I know that the calipers use 1/8" NPT connections. I've roughly measured, and at full droop, it looks like the distance between the frame fitting and the caliper varies from 9" and 13 1/2", lock-to-lock on the steering.
Now, if I average those two measurements, I get.... Ha, ha, just kidding, I don't think that anything shorter than the longest measurement would be a good idea....
But, that is actually quite a difference in length, and that extra hose has got to go somewhere where you're just motoring down the highway or making a sharp turn (and if you think about it, during a hard turn during braking, the caliper and the frame are going to be even closer on the inboard wheel), and it needs to stay away from the tire and the coilover, etc. The only fixed point in the plan is the through-frame fitting, which points out horizontally; the caliper mounting surface is also horizontal. But I can do 45* or 90* either through the actual hose:
http://www.summitracing.com/search?keyword=fra-312014&dds=1
http://www.summitracing.com/search?keyword=fra-342014&dds=1
http://www.summitracing.com/search?keyword=fra-322014&dds=1
or by using fittings:
http://www.summitracing.com/search?keyword=fra-481603-bl&dds=1
http://www.summitracing.com/search?keyword=fra-482203-bl&dds=1
http://www.summitracing.com/search?keyword=fra-482303-bl&dds=1
Does anyone have a similar setup that you can share pictures of or offer some advice on what routing methods might work best? I had purchased some 18" long hoses from Fragola, and they were closer to 19" in actuality, so I'm thinking that their 14" is probably the logical choice, but pointing it up, pointing it down, S-curve, trying to do a straight shot.... It just doesn't seem like there is a safe, sure-fire approach. Thanks for the input.
