View Full Version : How does manual master cylinder mount to firewall?
uraceulose
04-04-2013, 08:21 AM
This is probably a dumb question but from memory..my power booster and hydroboost both mounted to the firewall with 4 bolts in a square shape. The master cylinder I believe has 2 mounting holes straight across in a line. Is there a bracket that I'm supposed to get that will mount to the firewall first then the master to that bracket?
Donnie
dontlifttoshift
04-04-2013, 08:54 AM
No bracket, just use two studs.
uraceulose
04-04-2013, 09:00 AM
Ok, thank you. Am I supposed to use the upper or lower studs?
There are 4 sticking out from the brake pedal assembly through the firewall.
dontlifttoshift
04-04-2013, 09:19 AM
Which ever set lines the pushrod up with the upper hole in the brake pedal. I believe it is the top studs.
TheJDMan
04-04-2013, 02:25 PM
What car?
Skip Fix
04-06-2013, 04:02 PM
My 79 Camaro was top studs.
