View Full Version : Automatic Transmissions
- 4l60e (1 replies)
- PCS Trans Controller for the van? (8 replies)
- Need shifter help! (3 replies)
- stall size (3 replies)
- 200-4R Secondary Governor Spring Tech (5 replies)
- 1981 Trans am transmission (7 replies)
- 1962 Corvette restomod shifter (5 replies)
- 4l80e help (1 replies)
- Ford c6 (3 replies)
- 68camaro (0 replies)
- 4L80E shifter and shift handle 68 Camaro aftermarket console (1 replies)
- what trans did i just buy? 4l60e? 65? (1 replies)
- transmission pump (1 replies)
- transmission pump (2 replies)
- Paddle shifter/ trans controller lag times. (11 replies)
- Transmission clearance (0 replies)
- 4wd 4l60e or 2wd 4l60e (4 replies)
- Trans mount 6l80e with AM subframe (2 replies)
- What transmission for stock LS7? (3 replies)
- transmission ? (0 replies)
- bowler TV Cable (8 replies)
- gear star transmission (0 replies)
- 4l80e crossmember (1 replies)
- CTS Shifter for 4l80e? (0 replies)
- 6l80 in a second gen camaro? (0 replies)
- Are all repo camaro th400 lines 5/16 with 1/2-20 fittings? (1 replies)
- 700r4 (4 replies)
- 4l80e to a 350 olds (2 replies)
- 700r in my Oldsmobile (22 replies)
- transmission (0 replies)
- installed a 200R4 in my 64 F-85 post car (2 replies)
- What would make my TH400 do this (1 replies)
- 350 turbo Transmission Stall converter (0 replies)
- What to choose, what to pick - for high HP. (3 replies)
- th350 to 200-4r swap (14 replies)
- 6L80E with Paddle ShrifterSix Paddle Shift - Success (2 replies)
- Just installed a new 4l60e still slips..pcm problem? (10 replies)
- Shifter linkage shaft - Where to Buy? (1 replies)
- 6l80 in 1969 camaro (7 replies)
- Tranny break-in (2 replies)
- Best place to buy a 4l60e for a reasonable price. (22 replies)
- TH350 premature upshift from 1st to 2nd gear (1 replies)
- 83 700r4 (12 replies)
- quicksilver wiring in firebird (7 replies)
- 4l60e transmission harness plug-can it be installed backwards? (3 replies)
- I know beaten to death 700r4 converter (5 replies)
- Looking for SFI Bellhousing for 4L80e (3 replies)
- 4L80E early to late conversion (2 replies)
- overdrive trans for big block??? (19 replies)
- 4l60e shift problem (0 replies)
- 4L65 not engaging (19 replies)
- 4l60e ticking noise with speed problem? (3 replies)
- TH400 Not Working (2 replies)
- torque converter wont engage crank (1 replies)
- torque converter to crank problems, trans/engine already in car. (6 replies)
- PTCS six speed valve body for 4L80e (6 replies)
- what carb and tv cable bracket combo? need cheap, easy, and effective (3 replies)
- 2004R issues ! (14 replies)
- '68 El Camino, lumpy high comp. 350 engine, TH400 trans, need TC advice. (12 replies)
- 74 lemans help me! (3 replies)
- shifter question 70 camaro ls2 with 4l60e (1 replies)
- Th350 tran not shifting (4 replies)
- anyone using 4L70E out of TBSS? (17 replies)
- 4l80e tranny question (2 replies)
- Anyone try the TCI 6X 6speed (5 replies)
- 6l80e driveshaft yoke (6 replies)
- '06 4L65-e TCC signal? (4 replies)
- Ford Trans. (3 replies)
- Suggested 4L60E upgrades ? (3 replies)
- Opinions on the 6l80 (11 replies)
- LSX/4L60e - Convertor wont match up (14 replies)
- PCS push button shifter - is it fast? (15 replies)
- Trans lines/hoses..what iseveryone running? (8 replies)
- crossmember sugestions? summit/g-force does not fit. (9 replies)
- 4l80e vs Allison 1000 (5 replies)
- 68 Camaro 700R swap (6 replies)
- Lock Up or Non Lockup?? (17 replies)
- 2004R lugs on stops! (11 replies)
- G-Body shift indicator linkage won't work with Hooker Comp Headers (2 replies)
- Engine Braking?...or just the right Converter? (0 replies)
- need help with DD tranny (0 replies)
- 6L80 Stand alone trans controller ? (2 replies)
- 4L80e shifter suggestions (9 replies)
- c5 vette 4l60 trans, can it be converted to use in my camaro ls swap? (1 replies)
- TH350 Race Overhaul Kits.... (1 replies)
- 4l65e ready for upgrade, but whos qualifoed for a pro touring build? (3 replies)
- Manual Valve Bodies(TH350) (5 replies)
- 200r4 experiences? (25 replies)
- Th200r4 (2 replies)
- 700r4 not kicking down (0 replies)
- Th400.....I'm stumped!! (0 replies)
- Who makes tough TH350 Torque Converters? (8 replies)
- trans not going in any gear nut low. (1 replies)
- TH400 cooling (13 replies)
- kilduff shifter (0 replies)
- Shifter cable help (1 replies)
- 4l60 electronic question (0 replies)
- Women to look out to the particular pavements of just about one hundr (0 replies)
- Acculink Carb TPS (3 replies)
- So Much Frikkin Information...Help! (7 replies)
- Need 4L60E Shifter Cable for 4th Gen Console in 1st Gen Camaro (8 replies)
- 4L80E rebuild options (16 replies)
- 88-72 A-Body w/ 4L series transmission Pan Clearance? (8 replies)
- Accu-Link on a Roots blower (4 replies)
- Aurora and Northstar V-8 trans (1 replies)
- Did i BLOW MY TRANSMISSON UP..4l60e LSX SWAP CUTLASS (5 replies)
- Trans Dilemma: c4 w/ Gear Vendors OD or 4r70w? (12 replies)
- trans suggestions (4 replies)
- Simple Shift install issues (5 replies)
- Shifter cable routing (9 replies)
- Transmission Advice (4 replies)
- 700r4 odd draining problem?? (4 replies)
- 700r4 speedo Gear Housing? (1 replies)
- Paddle shifter help (8 replies)
- High stall converter, sluggish launch? (6 replies)
- Built 4l60e vs. built 4l80e (8 replies)
- Ford C6 manual (0 replies)
- Mad Dog Transmissions (9 replies)
- transmount 1 bolt? (1 replies)
- 4l80e flexplate (3 replies)
- Quick disconnects ??? (2 replies)
- 04 4L80E behind SBC in 85MCSS (5 replies)
- Sequential vs Paddle shifter (3 replies)
- Bump shifters (4 replies)
- 4L60e Out of Impala work in a 98 Z28? (1 replies)
- 200-4R lock-up control (17 replies)
- Best price and support (1 replies)
- Chrysler/Dodge 545RFE has slip (0 replies)
- bowler tv cable (5 replies)
- Chrysler 545 rfe codes (3 replies)
- Who is running a 6L90 in an A body? (3 replies)
- Who else other than Keisler makes a kit for 4L65 in a Mopar? (4 replies)
- 200R4 in a 64-65, trans line routing (7 replies)
- 700R4 Valve Body (0 replies)
- 700R4 Filter Change (1 replies)
- Best Shifter for 700r4 (7 replies)
- Torque Converter Fluid (3 replies)
- Will my B&M Mega Shifter work with a 4l80e (1 replies)
- 4l80e conversion, NEED ADVICE PLEASE! (4 replies)
- Cable or hard linkage shifter?? (7 replies)
- 4L60E Builder (6 replies)
- Converter choice (9 replies)
- 4l60/4l80 into 2nd gen f-body (1 replies)
- Need help with 4L70 rebuild options in Arizona (1 replies)
- 4l60e/4l80e (8 replies)
- Optishift or EZ TCU anyone use them? (13 replies)
- Has Anyone tried the New Rossler Transmission "little Black Box" ???? (6 replies)
- What size hose should I use? (2 replies)
- BMR Releases New Product: Transmission Conversion Crossmembers (TCC005, TCC030) (3 replies)
- Transmission fluid flow ? input,output (2 replies)
- Dual Clutch options? (4 replies)
- old or new 4L80E? Bolt pattern? (0 replies)
- Anyone use the Derale cooling transmission pan? (7 replies)
- Manumatic Display at Grand National Roadster Show (0 replies)
- 2001 Ram 1500 QC 4x2 46 re tans (1 replies)
- 4L80 in an A body (2 replies)
- TH400... For now. (6 replies)
- Shifter for 454RFE...HELP.. (1 replies)
- looking for hurst dual gate for 4spd (5 replies)
- Crossmember recommendation for 1st gen / 200 4r (13 replies)
- What the heck is this? (10 replies)
- Auto for Autocross/Track Days (19 replies)
- Jetaway to 200R4 coversion (0 replies)
- 4L60e Wiring Help Needed (2 replies)
- Any opinions on b&m black diamond shifter? (2 replies)
- Lokar locking TH400 dipstick ??? (5 replies)
- 6l80/90 (8 replies)
- Who makes ATM brand torque converters? (0 replies)
- 4l60E question .. blowing fuses? (3 replies)
- Ls1 5.7 4l60e conversion (3 replies)
- compushift II (0 replies)
- 4l80e mount to tail housing bolts??????? (0 replies)
- Converter for autocross / road race and cruisng (16 replies)
- Checking TCC on '93 4L60E (1 replies)
- trans adaptor (1 replies)
- 700R4 or 4L80 (0 replies)
- What stall speed should I use. (3 replies)
- Retrotek (17 replies)
- Transmission Advice... (3 replies)
- What OD auto behind a built Twin turbo 383 LT1 (4 replies)
- Bubbles (border line foam) on Trans dipstick (0 replies)
- 4l65 crossmember first gen (3 replies)
- 200R4 in a 64-65 F-85, having cross member relocation issues (6 replies)
- looking for a good Tranny builer in Charlotte NC? (1 replies)
- 4L80E Diesel? (1 replies)
- 200R4 Trans Question (1 replies)
- 4l60e years needed for ls (7 replies)
- need help with a stall converter (2 replies)
- Leaky 350 turbo (3 replies)
- Engine Dies In Anything But Park 4l80E (14 replies)
- how much fluid do I need for oil change in 700R4 (4 replies)
- 4l65 bellhousing what happened? (3 replies)
- 4TSB from FB Performance? (2 replies)
- 700 r4 speedo conversion (5 replies)
- fbody 4l60 dipstick length (0 replies)
- OE Performance - Auto Trans Builder Feedback? (0 replies)
- got a free 4L60E trans.... (2 replies)
- 700r4 with a blower? (5 replies)
- 4L60E in limp-home mode...can't figure out why (6 replies)
- 4l80e trans need help with setup (3 replies)
- So I killed my 4L60E... (0 replies)
- F-Body transmission cooler??? (2 replies)
- Think I cooked my transmission (9 replies)
- Anyone use 4l80e from early GM 1 ton (1 replies)
- monitoring tranny temp more important in a PT car or a drag car (3 replies)
- !!!!turbo 350 problems please help!!!! (1 replies)
- Broken BEAST sunshell (1 replies)
- TH350 Mystery part identification HELP (2 replies)
- 4L65RR-600 Manumatic System??? (1 replies)
- 700R4/ 4L70 questions (0 replies)
- Trans cooler...Anyone used something similar to this? (4 replies)
- 4l60e no 3rd or 4th gear (4 replies)
- Shiftworks 4 sp auto ratchet shifter (0 replies)
- Tci controller/paddle shift vs gmppp supermatic (4 replies)
- Problem with a 4L80 that no mechanic or automatic transmission tech can fix (3 replies)
- Anyone using the Compushift II? (2 replies)
- Found some tranny info that ithought you guys mightfind useful,, (0 replies)
- Anyone using the TCI EZ-TCU? (0 replies)
- Cost to Swap to TH350 or 700R4? (9 replies)
- Paddles for a stock steering wheel? (0 replies)
- 4l65 linkage (0 replies)
- calling all venders!! (6 replies)
- TH350 suddenly not shifting - No prior problems. Totally out of nowhere and sudden. (1 replies)
- bad converter? (4 replies)
- Need Help Installing Hurst Dual Gate Shifter (3 replies)
- What Shifter works best for a 6L90e/6L80e? (13 replies)
- split trans bellhousing in half!!! (1 replies)
- Compushift TPS calibration problem (1 replies)
- TV cable setup with quick fuel carb.... (3 replies)
- 4L80e: no cooler flow (1 replies)
- Master shift Opinions (2 replies)
- No rotation from 4L60E (7 replies)
- C4 going in and out of gear help.. (0 replies)
- trans cooler or not? (6 replies)
- Help with a part number (0 replies)
- Shifter for a 4l80 (0 replies)
- 4l60 bellhousings (2 replies)
- Torque converter for a Th350? (0 replies)
- T-42 connector controller (0 replies)
- Hurst pistol grip 3 speed converting to 4 speed???? (2 replies)
- Shallow pan for a 6L90e (35 replies)
- 200R4 no 2nd gear ??? (22 replies)
- Saw this on craigalist. (0 replies)
- 4l65 trans in a 1st gen camaro ?with a ls1 (0 replies)
- TH400 cooler suggestions (1 replies)
- Is there a difference in 4l60 years? (3 replies)
- Auto Trans for Ford 4.6 (1 replies)
- Paddle shifter, 4l80e, pushbutton shifter/touchscreen? (2 replies)
- 4l80 vs 4l65 (18 replies)
- HELP!! 4l80e problems (1 replies)
