Results 1 to 8 of 8
03-19-2012 #1
200R4 in a 64-65, trans line routing
Guys couple of us on the forum are building 64-65 Olds F-85 A-body cars and with a BB Olds with headers and a 200R4; there is very little room around the oil filter and the header tubes to get the cooler lines routed. Any ideas how too run the trans cooler lines and how close can you get to the header tubes??? 64-66 Chevelle's maybe the same or close but the starter is where the Olds oil filer is....
64 F-85 post car Resto-Mod project-my RV when I retire
04-03-2012 #2
New to Pro-Touring
- Join Date
- Jun 2006
- Location
- Orlando
- Posts
- 73
I have seen on other Turbo Buicks an idea that i considered using in the future. Removing the adapter inserts that the hard lines screw into on the trans leaving an NPT thread and using a flexible braided style line and running it thru the frame, or wherever you like. It looked killer!
Scott be me name, arrggg
06 TrailBlazer SS
86 Buick T Type WH1
86 Buick Grand National <RIP>
myspace.com/irvjr
04-03-2012 #3I thought of running the lines through the frame where the fuel line goes but there is only enough room for the fuel line, makes it real hard to figure out how to maybe drill out the restriction inside the frame, any ideas?
04-03-2012 #4
New to Pro-Touring
- Join Date
- Jun 2006
- Location
- Orlando
- Posts
- 73
You dont have to run it thru the frame. It can be routed anyway you like, as long as its out of your way thats all that matters. You can fab up some hangers and that way it can be seen and shown off.
06 TrailBlazer SS
86 Buick T Type WH1
myspace.com/irvjr
04-09-2012 #5Guys on a BB Olds in a 64 F-85 there is very little wiggle room for the lines to be routed with headers and the oil filter and adapter. I mocked up some lines yesterday with 5/16 rubber tubing and some ties etc. although I have nothing to compare to but at best seems to close to the header tubes and makes it real tight to get the oil filter off. but how tight is tight 1/2 inch, 3/8's? I'm thinking about a remote trans cooler mounted on the pass side, on other side of the cross-member between the pass exhaust and the frame rail ;totally away from the headers? Any ideas?
04-17-2012 #6
New to Pro-Touring
- Join Date
- Jun 2006
- Location
- Orlando
- Posts
- 73
Where are you located? Eyes on the project would help, so maybe someone is close to you and can be an extra set of of eyes and ideas.
06 TrailBlazer SS
86 Buick T Type WH1
myspace.com/irvjr
06-03-2012 #7I live in the Dallas area, thanks
06-04-2012 #8See if Jakeshoe has any ideas. He does a fair amount of 200Rs and is just north of Dallas.
http://jakesperformance.com/1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
1981 Trans Am 400 stock type motor
79 Camaro getting a 500" 695 hp IA2 Pontiac motor
1965 GTO project car
470ci/Chevy dual quad 409 604 HP 64 Impala SS project
2004 Pulse Red GTO
