    Results 1 to 7 of 7
      Jul 2010
      Country Flag: North Korea
      High stall converter, sluggish launch?
      I'm trying to figured out some of the issues with my car as a recent track trip was pretty dissapointing. So today for S&G's i thought i'd go out and try some hard launches with my car's 3000 stall converter. The cam i have in the car called for a 2800rpm converter, but i went 3000 due to a good deal and thinking that 200rpm shouldnt make much of a difference right?
      I tried several different techniques:
      -Foot on the brake, very light on the gas, release as i roll into the gas
      -Stall up just before tire spinning, release while quickly laying into the gas
      -Stall up to spinning and launch
      The problem is that every time the car just fell on its face gave a rather piss poor launch. So i much so that i think it the car got off the line quicker when i just stabbed the throttle.
      This is a PTC 3000k converter on a mopar 904 transmission with an unknown number of miles.
      I meal isnt a stall converter suppose to have a full launch thats akin to launching a stick car at said rpm? I wonder if maybe its the transmission itself thats slipping on the launch??
      Mar 2010
      Okinawa, Japan
      Are you 100% sure its a trans thing, sounds like the engine may not be able to handle the load. You need to have a lot of timing and the right AFR at launch to footbrake with good traction. Are you carb'd or FI?
      Jul 2010
      Well now I'm not entirely sure. I'm running an edelbrock carb setup. After I posted this I read a small blurb about having bog issue on a launch because of the accel pump. So I moved the pump adjustment to its max shot position and went for a ride. I couldnt try any launches, but it made a massive difference in how the car would react on just a wot hit.
      Mar 2010
      Okinawa, Japan
      Sounds like you're onto something, try some launches and see if things inproved. I think a carb can run almost as well as fuel injection, you just need to tune it right. The absolute best investment I've made in my money pit of a car has been the wideband O2 sensor and analog gauge setup, probably less than $250 total cost and has been amazing at helping with the tune!
      Jul 2010
      Quote Originally Posted by carguykeith View Post
      Well the carb setup is temporary. I didnt want my money pit to include 2k worth of efi parts if it wont run well on an carb.
      I may need to spring for a wide band setup. Do you run just one sensor on one bank of the exhaust or two sensors?
      Mar 2011
      Ca
      when there is a problem with launching, or hitting the throttle in general and there is an issue the first thing i look at is the accelerator pump adjustment.
      Mar 2010
      Okinawa, Japan
      I made the same choice, it should at least run good enough on the street and pull hard at the track with a carb to know if I'm happy with the drive-train. I bought the carb used so figure I can get most of my money back when I go FI.
      As for the O2 sensor, I'm just running one sensor and figure as long as I do everything the same on both banks and check the spark plugs every once in a while it should be fine. Hell the manufacturers have been doing it forever that way... After having an AFR gauge I wouldn't have a project without one and would even keep the gauge after going FI.
