gui67
04-29-2011, 09:03 PM
I installed my freshly rebuilt 4L80 in my car, but I saw that I have no flow flowing trough the cooler:
I removed the fitting (bottom front) and nothing comes out with the engine running.
I drove ~25 miles like that.
It is a 92 model with both cooler lines in the front. What could I have done wrong during the rebuikd?
I saw on the principle of operation that the lube comes from the TCC switch valve. The TCC is OK: it did work when I drove.
where does the cooled lube then go on a 92 model (the principle of operation manual is for rear return fitting models) Is there a risk I broke something?
I replaced the pressure solenoid during the rebuikd; I saw yesterday that there a 2 models: one with blocked tip and a second one with a filter on the tip. Is it possible to have these symptoms if I used the one with a blocked tip?
