View Full Version : Tci controller/paddle shift vs gmppp supermatic
fastfoot
06-12-2011, 11:22 PM
I have an 4L85E Trans from GMPP with an GMPP contoller, Can i use the paddle shift from TCI on the GMPP controller ? The software and controller looks the same, both have CAN connectors. anyone ?
68Formula
06-13-2011, 07:50 AM
Is this the one you have? http://www.crateenginedepot.com/SuperMatic-Transmission-Controller-19257634-P9105C0.aspx
If so, it looks suspicously like this one: http://www.powertraincontrolsolutions.com/transcontrol.php. Which looks a heck of a lot like this one: http://www.tciauto.com/base/files/PDF/Help/index.htm (a quick glance, the calibration tables in the instructions look the same too).
I'd say from looking at everything, PCS supplied these to both TCIAuto (which now has their own TCU based on the FAST controller hardware) and GMPP. And both TCIAuto and PCS are supposed to be paddle-shift capable.
And if you look at 2.2.8 of the installation guides online, they do list a "bump stick" operation: http://www.gmperformanceparts.com/_res/pdf/installation_guides/transmissions/SupermaticTransmissionControllerKitInstallationGui de.pdf
Perhaps someone else can give a definitive answer, but I think you're good to go.
parsonsj
06-13-2011, 08:56 AM
I would call Powertrain Control Solutions and ask them. I found their tech support to be marvelous even for their resellers like TCI and GMPP.
fastfoot
06-15-2011, 04:27 AM
Got an message from TCI today, where they confirm that the TCI paddel`s works with GM Supermatic
fastfoot
08-25-2011, 10:21 AM
Mounted the TCI paddel`s today with GM Supermatic control module and it works !! just plug and play !
