View Full Version : Think I cooked my transmission
Toadman
07-16-2011, 10:58 AM
Any quick fixes???
Participating in Heidts Challenge right now! If I give the car a lot of throttle is doesn't want to go anywhere. If I ease into the throttle, seems better. This is also my ride home! HELP!
79-TA
07-16-2011, 11:52 PM
Is this an automatic transmission we're talking about?
JEFFTATE
07-18-2011, 01:01 PM
Put some of that Lucas Auto Trans Additive in it and take it easy 'till you get home ..
Toadman
07-18-2011, 03:58 PM
Yeah, probably should have mentioned that it was a 4L60E, but I was a little frantic at the moment... Called all over on Saturday trying to find a shop that was open with no luck. I limped to the nearest Jiffy Lube, and had them do a quick tranny fluid flush. Kinda got 1st & 2nd gear back, but not enough to drive it home. I ended up talking my brother into coming out to Joliet, about an hour from home, and trailering it back.
Weighing my options now...
MyFriendScott
07-19-2011, 08:12 AM
Burned out the clutch packs? Did you smell the fluid before having Jiffy Lube work on it?
rrunner68
07-19-2011, 10:00 AM
Yep. Toast.
Toadman
07-19-2011, 10:54 AM
Pretty sure I burned out the clutch packs. Smelly and smokey. (Names of 2 new dwarves? :razz: )
Looking into my options whether to rebuild my 4L60E with a cooler or go 4L80E. Only pushing about 380 hp/380 ft. lb. tq., so I don't think I need anything real beefy... yet.
Scott Parkhurst
07-19-2011, 11:10 AM
Seen this?
https://www.pro-touring.com/showthread.php?81500-Hughes-Performance-4l60E-with-converter
Toadman
07-19-2011, 11:13 AM
Oooooh, no I haven't. Thanks!
Steve68
07-19-2011, 01:24 PM
4l60 barely hold up behind a 4 cylinder in a Sonoma truck, wrong choice in trans, modify it an add clutch packs, vette servo, "The Beast" sun shell, trans go shift kit and a cooler, might last then,
