DCx
01-29-2014, 09:31 PM
I bought this trans on craigslist from a local off road buggy/sand car fabrication shop. I was told it was a 2001 4l60e from a 2wd Silverado. i looked up some of the number of the trans and it looks like its from a V8 but the case dosnt say 4l60e on the side. need to know if i can make this trans work behind my 5.3 swap.
bell housing has the 12 o'clock bolt hole and this part number - 24206952, which translates to a 4.8/5.3/6.0 bell on google.
main case is stamped - 24207965
it has a 6 bolt tail shaft, 13 pin connector on the side, a PWM front pump, and a double splined input shaft with an O ring in the center.
also the torque converter that came with it lines up perfectly with the holes on my dished 5.3 flex plate.
https://static1.pt-content.com/images/pt/2014/01/C8DBBA0691364ED7823B39856B86984E-1.jpg (http://s127.photobucket.com/user/justingiese/media/C8DBBA06-9136-4ED7-823B-39856B86984E.jpg.html)
https://static1.pt-content.com/images/pt/2014/01/A0B2EC0DCAAF4E0EA37EDF0C9670EE03-1.jpg (http://s127.photobucket.com/user/justingiese/media/A0B2EC0D-CAAF-4E0E-A37E-DF0C9670EE03.jpg.html)
https://static1.pt-content.com/images/pt/2014/01/AB7DE21A042047979B488BF39ACE5717-1.jpg (http://s127.photobucket.com/user/justingiese/media/AB7DE21A-0420-4797-9B48-8BF39ACE5717.jpg.html)
https://static1.pt-content.com/images/pt/2014/01/C43DA2E0836A42699E549C197C9BC502-1.jpg (http://s127.photobucket.com/user/justingiese/media/C43DA2E0-836A-4269-9E54-9C197C9BC502.jpg.html)
yes i know one tab is broken...
https://static1.pt-content.com/images/pt/2014/01/59457CD0A8EC484CA983C64B07421841-1.jpg (http://s127.photobucket.com/user/justingiese/media/59457CD0-A8EC-484C-A983-C64B07421841.jpg.html)
