View Full Version : 700r in my Oldsmobile
cutlassmann
10-27-2013, 02:39 PM
Hi I need some help thinking about going with a 700r I have a TH350 with 22-2600 stall in my 72 cutlass and I have a 350 Oldsmobile motor my cam spec 520/523 lift at 60 mph my rpm is 3000 I think is to high and I have a 3.42 gear do u guys think 700r would be good thanks
1966longroof
10-27-2013, 03:27 PM
3000 rpm at 60mph with 3:42 gears?? How tall are the tires?
cutlassmann
10-27-2013, 04:47 PM
295/35/18in the rear
cutlassmann
10-27-2013, 04:49 PM
I'm sorry at 70 it's 3000-3100
sam 74
10-27-2013, 05:22 PM
a buddy of mine has a 700r4 in his 71 cutlass with a 455 and 3.73 gear, but hes running 275 60 15 tires and his rpm is really low, i can't remember the exact number since its been a while since we've talked but he has about 450-500 HP in that setup and it runs reliably.
69cutlassrkt
10-27-2013, 05:25 PM
My choice would be the th200-r4, since the gearing is better. Having a 4l60e I do not care for the first gear to 2nd drop.
cutlassmann
10-27-2013, 05:48 PM
200r4 cost double to build than the 700r
1966longroof
10-28-2013, 02:40 AM
You'll like it. I have one in my car. Don't worry about the cam lift. You take care of that with the Torque Converter. Choose one in the low to mid 2000 rpm range. But of course talk to the torque converter specialists. (it's the duration and lobe separation that usually cause fits with street-ability).
Steve Chryssos
10-28-2013, 07:18 AM
You can tune the 1-2 shift so that it happens at a lower rpm.
Steve Chryssos
10-28-2013, 07:36 AM
200-4R are expensive because usable cores are rare as hens teeth. It has a great performance reputation after decades of development, but as a platform, it's still a dinosaur. Like a SONY Walkman. ..And if good cores are hard to find, how can you be sure you are getting a good core? ..Or that if your good 2004R blows up, that you'll be able to find another. I still like the transmission from a functionality standpoint. Just be sure to factor in the realities of availability. You're investing in something that was designed in the 70's (introduced in 1980) and hasn't bee produced in almost a quarter century.
djfxall
10-28-2013, 09:05 AM
Love my 700r4 the recent refresh rebuild is almost done on it judt have to save my pennies for the torque converter. Great on the highway and first is a screamer. Suggest if go that route buy reputable the first time or build your own.
cutlassmann
10-28-2013, 01:26 PM
So who builds a good 200r4 are the 700r and what good size torq to go with ?
tmgant
10-28-2013, 05:10 PM
Well the 200r4 as a multi-bell so it will bolt to your bpo. And it is the same length as your 350. The 200 has a 2.74 first, the 700 has a 3.07 first. The rpm drop at 3-4 shift is 650-700, add the lock-up 200-250rpm more drop. hope this helps Tobby
cutlassmann
10-28-2013, 07:20 PM
So what would you go with 200r4 are 700r and what brand????
tmgant
10-29-2013, 04:57 AM
200r4 Stage 2 with a 23-2500 convertor, and the one wire lock-up. Tobby
cutlassmann
10-29-2013, 08:01 AM
But From who (brand)
69cutlassrkt
10-29-2013, 10:08 PM
It's 1-2 shift is pretty low. I meant like when going wot. My car is back to having a stock converter, so it's a little more noticeable. The 1-2 shift isn't really a big deal just for when racing and those rpms drop.
Cutlassmann I think tobby meant going with one of his transmissions
tmgant
10-30-2013, 04:50 AM
Not necessarily my trans, there's company's out there that offer good products. Do your research and talk to them, then decide. Not trying to push something on you, just giving some info. thanks Tobby
cutlassmann
11-02-2013, 07:07 PM
Tobby what's your website for your transmission
streetnova74
11-03-2013, 12:48 PM
The link is in his signature.
cutlassmann
11-04-2013, 01:48 AM
So would it be better for me to change my gear down from a 3.42 and keep my th350 and what would be a good highway gear to run if I do change it thanks...
cutlassmann
11-06-2013, 06:31 PM
Is Bowler Performance Transmissions better than Extreme Automatics and why?
silvermonte
11-06-2013, 07:28 PM
I would swap over to the 700r4, that overdrive is nice and it allows you to have a decent gear to still get up and go.
