View Full Version : 700 r4 speedo conversion
Coursey
07-30-2011, 05:15 PM
I just bought a 700r4 and did not relize that it has an electronic speedo. My nova has a mechanical speedo.
Can you convert the 700 from electric to mechanical speedo?
TT302Z28
07-31-2011, 07:54 AM
I know that you can buy a converter but it is expensive. You may be able to change your tail housing if your output shaft has the pad for the gear. Not sure if all 700R4 shafts have it.
Are you running the stock or aftermarket speedo? If aftermarket do they make an electronic version of your set? If so change the speedo, cheaper and more reliable.
Coursey
07-31-2011, 09:16 AM
Now I have the stock speedo for a 1966 nova.
To buy complete new guages would run $500- $800.
TT302Z28
07-31-2011, 11:52 AM
I'd look at the possibility of the tail housing change then.
66zz430
07-31-2011, 05:22 PM
Give this place a call, they should be able to help you :http://www.transmissionpartsusa.com/
Coursey
08-02-2011, 05:41 PM
Turns out that the trans had a mechanical speedo with an electric adapter screwed in.
https://static1.pt-content.com/images/pt/2011/08/d505cdb8-1.jpg
