View Full Version : The LSX Forum
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13
  1. LSA vs LS6 differences (13 replies)
  2. Future LS Build Advice Needed (15 replies)
  3. to build my ls1 or sell and rebuy a 6.0 (3 replies)
  4. Harness wrap (3 replies)
  5. Thoughts/opinions on connect & cruise engine combo 2nd gen (8 replies)
  6. LS3 engine intake/plenum cover??? (3 replies)
  7. Are 06 GTO ls2 accessories the same as 06 Corvette LS2... (3 replies)
  8. Would this accessory drive work? (4 replies)
  9. Will G8 6.0 (L76) complete motor with accesories..... (6 replies)
  10. 1st Gen Camaro LS swap cold air induction (4 replies)
  11. Gm lsa crate motor fuel pump requiremetns (4 replies)
  12. Harmonic Balancer ID (5 replies)
  13. Complete bolt kit for LS engines? (0 replies)
  14. ? on LS1/2/6 intakes/rails/inj (8 replies)
  15. Dyno before install? (3 replies)
  16. Balancer installation - Loctite? (3 replies)
  17. Broken header bolts. (9 replies)
  18. ls crate engine choice (15 replies)
  19. LS3 lost power at high elevation (9 replies)
  20. 2nd gen F-body w/6L80e???? (49 replies)
  21. Question LS2?? (21 replies)
  22. When is a dry sump needed? (7 replies)
  23. Ls1 or vortec ecm cleaning or painting. (1 replies)
  24. How to build an LS engine resources (5 replies)
  25. Keep my harness or get one made? (3 replies)
  26. Gas Huffer Hot Rod's next LSX Engine Package? (4 replies)
  27. New Bullet Pics (18 replies)
  28. motor lift with intake on (8 replies)
  29. Using accessories drive from 2012 Camaro (3 replies)
  30. Recommendations needed 1st Gen Camaro Owners (3 replies)
  31. 4l80e ground clearance shallow trans pan (4 replies)
  32. Valve Covers (0 replies)
  33. Carbon build up (3 replies)
  34. LS3 oil filter fitment issue (13 replies)
  35. Whats needed for ls9 swap (15 replies)
  36. LSx/a-body motor mounts, what to look for (7 replies)
  37. Want an easy LS swap kit with matched parts that really fits? (7 replies)
  38. 5.3 lm4 question (5 replies)
  39. Anyone families with ....? (1 replies)
  40. No coolant flow (4 replies)
  41. Question about accessory drive systems (19 replies)
  42. to LSA or not LSA that is the question (20 replies)
  43. 67-69 Camaro LS Swap guys... (17 replies)
  44. Just got a LQ4 putting a F1R on it... What else? (11 replies)
  45. L94 good buy? @ $1500 complete? (4 replies)
  46. LS cooling fan question (9 replies)
  47. How much is TR 6060 worth? (3 replies)
  48. Interchangeable wiring harness and headers? (1 replies)
  49. HELP** Please help identifying these parts (4 replies)
  50. LSX Alternator Bracket Identification Help (4 replies)
  51. Trans tunnel fabrication (2 replies)
  52. DIY LS Cam swap Tools (4 replies)
  53. truck headers (1 replies)
  54. ls2/ls3 (1 replies)
  55. accessories off gmpp fuse/relay box (0 replies)
  56. more power questions for the engine guys (5 replies)
  57. ls3 fuse relay box wiring help (1 replies)
  58. Were are you guys finding your llsx motors? (9 replies)
  59. Help me identify these coil and fuel rail covers (4 replies)
  60. 67 Camaro - LS conversion - Radiator & Condenser mount question (2 replies)
  61. alternator swap? (0 replies)
  62. Ly6 6.0 317 heads ported and polished for $1800 good deal? (7 replies)
  63. KATECH LS3 Torquer CAM (3 replies)
  64. LS Fuel tank options (6 replies)
  65. New Detroit Speed and Engineering Tech Series Video on VaporWorx Fuel Systems (9 replies)
  66. Came across a G8 LS2...will it require more than just a cam swap... (10 replies)
  67. Need LQ4 Swap Advice for 1984 Monte Carlo SS (4 replies)
  68. Going to try and rewire my own harness and pointers? (4 replies)
  69. 68 Camaro Ls1 what power steering line? (1 replies)
  70. lq4 vs lq9 (18 replies)
  71. how much is too much (miles) (6 replies)
  72. Ground Clearance pic of Gen 1 Camaro LS swap (15 replies)
  73. need HELP with fresh built car issue (3 replies)
  74. Larger oil filter (2 replies)
  75. LS3 starter recommendation (4 replies)
  76. L96, pull trigger? (4 replies)
  77. alt. notch for new hooker ls1 Fbody kit? (1 replies)
  78. Recommend a wideband (8 replies)
  79. GMPP 454 Kit? (14 replies)
  80. Don't want to notch my frame. What LS options are there? (6 replies)
  81. Power Steering Reservoir Location (0 replies)
  82. Harness question (1 replies)
  83. Things to take care of before putting in a pullout motor? (5 replies)
  84. 71 Malibu w/ blown LS3 (3 replies)
  85. Need input on this ride: (2 replies)
  86. What are people doing with ECM and Fuses? (4 replies)
  87. LS1 swap voltage regulator (6 replies)
  88. Supercharged 5.3 or LS2 (10 replies)
  89. Old Cars and New Engines: What's considered enough power? (19 replies)
  90. LS swap run away RPM upon start up (11 replies)
  91. LS1 HP Upgrades - under 1500$? (20 replies)
  92. What would you change? (4 replies)
  93. Safe amount of time (2 replies)
  94. Corvette power steering pump fitting? (1 replies)
  95. LS2/T56 swap help (4 replies)
  96. 6.0L LQ9 Build options (5 replies)
  97. Ls2 hesitation (9 replies)
  98. Fuel Pump Question (1 replies)
  99. Too close for comfort??? (7 replies)
  100. LSX donor car for a 68 firebird (6 replies)
  101. Improved Racing oil pan baffle (2 replies)
  102. RICK' S tanks question (8 replies)
  103. Is there a rule for how many bends you can have in intake tube? (3 replies)
  104. lsx-harness.com? (0 replies)
  105. Value of a 1999 LS1 (7 replies)
  106. New Holley 302-2 Oil pan with Ridetech tru-turn? (18 replies)
  107. Late-model GM LSx takeouts - prepped for retrofit applications - who does these? (3 replies)
  108. ls1 oil pan broken? (3 replies)
  109. self tuning controllers for l92 and 4l80e (6 replies)
  110. To intercool or not to intercool supercharger (17 replies)
  111. Pros/Cons of Speed density tuning HCI LS1 (8 replies)
  112. How to make sure engine doesn't have DoD? (4 replies)
  113. ls2 with T56 in A 72 Chevelle wagon. (1 replies)
  114. HELP!!! ls3 crate motor needed! (10 replies)
  115. What accessories drive to use for l92 going into second gen camaro? (4 replies)
  116. LS Mock UP Block (7 replies)
  117. Dirty Dingo Sliders in my '69 442 (0 replies)
  118. How to care for a ls on engine stand? (3 replies)
  119. ATS LS7 Oil Pan Larger Stroke Fitment (0 replies)
  120. LS Basics...help! lol (11 replies)
  121. LS2 vs LS3 (8 replies)
  122. 68 firebird ls swap (3 replies)
  123. LS1 with Drive by Wire (3 replies)
  124. Looking for input on a very hot subject! (17 replies)
  125. LS3 Corvette Fuel Rail Covers (8 replies)
  126. Starter opinions? (3 replies)
  127. Which manual transmission for an ls engine?!? (4 replies)
  128. LS2 GTO Rail Cover on a Ls3 (2 replies)
  129. Ls2 carb vs efi? (4 replies)
  130. Smooth LSx valve covers? (2 replies)
  131. HELP Need help with wiring on an ls swap (4 replies)
  132. Accessory drive with ChassisWorks subframe... what fits? (3 replies)
  133. DBW throttle pedal (13 replies)
  134. need help with parts list for my t56 swap on my 68 camaro ls swap (1 replies)
  135. headers that fit - dse steering box in the way (9 replies)
  136. Key on, engine off, will DBW throttoe blade open with pedal? (2 replies)
  137. Used LS Motor - How Many Miles Is Too Many? (12 replies)
  138. LSX454 Oil filter relocation hose length. (0 replies)
  139. LSA crate engine in a 68 camaro (2 replies)
  140. TAC module? (1 replies)
  141. Feedback on Mast Motorsports Black Label LS7? (2 replies)
  142. LS Swap headers (50 replies)
  143. HELP Need help with wiring on an ls swap (3 replies)
  144. ls 5.7 engine (4 replies)
  145. Norris Motorsports Mail Order, E-mail & Remote Calibration Now Available (0 replies)
  146. Anyone running the LS376/525 ? (5 replies)
  147. Jegs LSX 454 Build? (2 replies)
  148. FAST EZ EFI 2.0 on an LS???? (2 replies)
  149. Cylinder head issues Tahoe 5.3 -02 (14 replies)
  150. Mike w/ New Era Performance In Las Vegas for Tuning Jan 22-26 (0 replies)
  151. Opinion on headers for my lowered 69 Camaro w/ LS motor (21 replies)
  152. Holley HP EFI vs. GM Computer (20 replies)
  153. custom motor mounts (7 replies)
  154. Need help on decision on what motor on budget of $2500 (10 replies)
  155. What exactly is needed to make a ls actually turn and run in a classic muscle car (8 replies)
  156. LS engine decision. Need help quick! (22 replies)
  157. Holley LS oil pan on a first gen f-body (5 replies)
  158. What LS ignition coils should I buy? (16 replies)
  159. ASA Cam? (17 replies)
  160. DSE fuel injection tank vs Aeromotive Phantom w/ stock tank (33 replies)
  161. Mike Norris EFI Calibration Work Avail Feb 11 & 12, 2014 in SoCal (1 replies)
  162. fuel tank mods for in take pump (17 replies)
  163. 72 nova ls swap parts with ride tech parts (5 replies)
  164. Gen 4 l92 standalone wiring harness diagram? (0 replies)
  165. vortec 5,3 to 1967 camaro (13 replies)
  166. LS3/525 F.I. Idle rpm ? (2 replies)
  167. Which Motor would you use? (3 replies)
  168. Lsx swap manual or automatic?! (8 replies)
  169. 2011 L96 silverado 6.0 engine spec question! (3 replies)
  170. 6.0L in a 67 woe's (41 replies)
  171. L92 fuel injector plugs (2 replies)
  172. LS swap shop in sf bay area (2 replies)
  173. ls1 oil pan on l92? (5 replies)
  174. The "What If It Was Yours..." LQ4 engine thread... (8 replies)
  175. Best ls adapter plates for 2 gen camaro (1 replies)
  176. New Holley 302-2 oil pan now available (14 replies)
  177. Blueprint LS 427 (3 replies)
  178. L92 with t56? (9 replies)
  179. LS Swap and ECU mounting location? (4 replies)
  180. LS help (9 replies)
  181. LS6 Motor w/460L Auto trans Help!!!! (2 replies)
  182. 68-72 gm a body headers? (0 replies)
  183. lsx salvage car pull (7 replies)
  184. need some help please (6 replies)
  185. is lokar the only LS throttle cable option? (3 replies)
  186. GM Performance LS3 or Builder? (5 replies)
  187. LT1 to 1967 camaro (6 replies)
  188. Nice combo for LS3s with drivablity and broad power band (0 replies)
  189. Best fitting oil pan for 5.3 in a 67 Chevelle (10 replies)
  190. GMPP LS3 harness- looking for CEL wire (15 replies)
  191. New LS3 crate Engine - Idles HIGH (2 replies)
  192. does Dirty Dingo DD brackets, hooker headers and holley pan work together??? (11 replies)
  193. lt1 swap Datsun (2 replies)
  194. VVT accessory drives... (2 replies)
  195. 5.3 Combo help.... (24 replies)
  196. Going to take the plunge and convert to FI (2 replies)
  197. Danny Popp 72 (0 replies)
  198. Hooker 1st-gen F-body/3rd-gen Nova Trick or Treat tease (151 replies)
  199. Builders using LS9 supercharger (8 replies)
  200. Best way to get hand on a LS7 Engine?? (28 replies)
  201. brackets to move T56 shifter to stock location on 68 camaro??? (0 replies)
  202. Universal weld in motor mounts? (1 replies)
  203. eBay LS1 gas tank for 68 Camaro?? (13 replies)
  204. Wet sump LS7 into a 69 - which conversion mounts? (5 replies)
  205. Cam Selection 2004 LS1 (9 replies)
  206. LS1 budget swap parts??? (5 replies)
  207. LS3, 430hp upgrade? (7 replies)
  208. intake y-pipe where to buy (1 replies)
  209. Value of an LS1 longblock (3 replies)
  210. LS7 / 9 Dry Supm Oil Pan by Speedtech/ ATS is BACK (5 replies)
  211. 72 chevelle ls swap (33 replies)
  212. 1986 El Camino G Body LS Swap Stainless Headers swap- need info (3 replies)
  213. How would you build a LSX376 B-15 (3 replies)
  214. LS conversion company (4 replies)
  215. LS1 MAF Selection (10 replies)
  216. Issues with lsx swap combo. (11 replies)
  217. AGR power steering box (3 replies)
  218. LS2/LS3 -6 speed install in a G Body- Need Serpentine belt install info (23 replies)
  219. need a ls 6speed dropout for a 2007 canyon p/u (3 replies)
  220. LS2 swap - scan data output issue (2 replies)
  221. Can you truely " Plug and Play"? (3 replies)
  222. Th400 swappers use this! (2 replies)
  223. Fuel tank question (19 replies)
  224. LS1, whats wrong with my engine? See pictures (9 replies)
  225. LS376/525 break in (6 replies)
  226. LS3 T-Stat housing ? (5 replies)
  227. Deceleration fuel enrichment (1 replies)
  228. MAF placement? (6 replies)
  229. Lookinmg for a Magnacharger for LS1 (2 replies)
  230. GTO tank into 1st gen F-body (0 replies)
  231. What crossmembers and driveshaft work for an ls swap in a gen 1 camaro? (41 replies)
  232. What is this thing on the negative battery cable? (1 replies)
  233. How to get an LSX started for the first time? (16 replies)
  234. Parts needed for hydraulic clutch setup 1968 Camaro LS3 (0 replies)
  235. LS2 custom fuel rail covers ? (4 replies)
  236. L92 swap into 69 camaro (6 replies)
  237. GM controller outputs (4 replies)
  238. Looking for a fabricator to make me a custom intake ls7 for kenne bell (10 replies)
  239. HP Tuners Data.....anybody a whiz at troubleshooting? (1 replies)
  240. Crankshaft Pulley (Before I do Something Stupid) (2 replies)
  241. 1964 Buick Skylark has 30k on its original 300 v8.... but i have a 5.3l w/1000 mi (5 replies)
  242. Bellhousing... did i order the right one (6 replies)
  243. Corvette alternator connection? (7 replies)
  244. Air Intake - Alternative Routing on 1970 Chevelle? (7 replies)
  245. timing cover front cover 2009 5.3 (0 replies)
  246. 1966 Malibu LSX376/T56 PT attempt... (45 replies)
  247. Ls3 480 HP crate (28 replies)
  248. Is this an LS3 or an L92 truck motor? (10 replies)
  249. LSx Under Drive Pulley....Benefits out weigh the risk? (10 replies)
  250. ls swap with stock f-body oil pan? (1 replies)
