View Full Version : lsx salvage car pull
71maroesteban
11-24-2013, 03:41 AM
Just wanted to know what I should grab to make the swap into my 71 camaro complete the vehicle is a 07 Denali 6.2 l92 and 6l80e truck was hit and my uncle said I can go at it so what should I grab computers etc and where is the best place to hook up the cherry picker?
Mr.VENGEANCE
11-24-2013, 07:16 AM
EVERYTHING engine and wiring from the tranny to the serpentine!
ALL UNCUT electronics!!
71maroesteban
11-24-2013, 08:14 AM
ALL UNCUT electronics!! okay but like specifically I'm never attended to remove a ls so that's why I really have no idea what to grab I guess I might as well take all wiring in the car to be sure I don't leave anything behind!
Route66dan
11-24-2013, 09:32 AM
Unplug EVERY wire. Don't cut any wiring. Also, get the driveshaft, or at least the yoke into the trans so you can adapt it into your application. Lift the engine wherever you can without damaging the plastic parts. A long strap is probably better than a chain. Cut the down pipes below the O2 sensors and get them as well. You'll thank yourself.
1989GTA
11-24-2013, 10:45 AM
Don't forget the accellerator pedal.
raustinss
11-24-2013, 10:57 AM
Write down the vin number somewhere and keep it close, I know sometimes when buying parts you need the vin number the differentiate different models
garys 68
11-24-2013, 02:26 PM
Accessories will come out with it. But take the coolant hoses, PS hoses, AC hoses (you'll find out why later), Intake tubing with MAF, exhaust with O2 sensors, all wiring wiring (including battery, ground cables) to ecu and any other modules, ie TAC (cant remember if 07 still had a TAC),FCS, battery, maybe even the bcm. Deinitely get the gas pedal assembly with harness. Might as well get the fuel pump if you can.
DO NOT lift by the metal ring behind the fuel rail. It's intended to protect the rail in collisions. Use bolts to the heads, block, accessories.
HwyStarJoe
12-05-2013, 05:46 PM
If you remove any covers, won't there already be 2 lift hooks mounted kitty-corner from each other?
